RV.Net Open Roads Forum: Class A Motorhomes: Bad Lippert O ring
 > Bad Lippert O ring
AikenRacer2
Aiken, SC
Posted: 11/04/22 11:45am Link  |  Quote  |  Print  |  Notify Moderator
I have had a small hydraulic leak from the pump system for a while. I finally narrowed it down to the o-ring between the plastic tank and the pump itself. It's a 3.5" o-ring. Looks like whoever installed it did not get the o-ring in level all the way around as it had a twist in it. Ok, I'll just get a new o-ring from Lippert and replace it. Well, much to my surprise, Lippert will not sell replacement o-rings. What a crappy way to treat a customer who spends mucho money on their products. I could probably rotate the o-ring to the top so that it's above the fluid level but I'd rather fix it right. Other than Amazon, where could I get a replacement O-ring that has a flat surface? Lippert stinks!
rgatijnet1
Posted: 11/04/22 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I would guess that any hydraulic shop should be able to help you. Most any area will have a shop that repairs the millions of farming and construction equipment that uses hydraulic rams on the equipment. I am sure that Lippert did not re-invent the wheel and probably used an O-ring that was already in use on another ram.
dougrainer
Carrolton, Texas
Posted: 11/04/22 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I would clean the aluminum and the plastic tank and dry. Thes use a Permatex type gasket maker and put a bead and reinstall. There is no real pressure on the system from the reservoir tank. Other than the pressure of the liquid sitting in the tank. Doug
dougrainer
Carrolton, Texas
Posted: 11/04/22 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
https://store.lci1.com/o-ring-325in-35in-2-2363510000104-359172
Tom/Barb
Oak Harbor, Wa
Posted: 11/04/22 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
ACE Hardware, match them, and install with Vaseline.
AikenRacer2
Aiken, SC
Posted: 11/04/22 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Wonder why the lady told me Lippert doesn't sell o rings??
The ones on their site don't appear to be the right size.
I did email Lippert with the specs to see if someone else can help me.
Thanks for the responses!
Bird Freak
Dallas Ga.
Posted: 11/04/22 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Have you looked at the pump? Odd's are Lippert doesn't make them.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
dougrainer
Carrolton, Texas
Posted: 11/04/22 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
My link shows 3 1/4 and 3 1/2. Doug
Ray,IN
IN, USA
Posted: 11/04/22 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Right on!
FWIW, I have an "O" ring kit that is a "make your own" kit. It comes with various diameters of "O"ring material and a special glue. Cut to length and glue ends together.
So you are right, alternatives are out there.
* This post was edited 11/04/22 05:48pm by Ray,IN *
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
Pbutler97
Midwest
Posted: 11/05/22 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Ray,IN wrote:
Right on!
AikenRacer2 wrote:
Lippert stinks!
That's putting it mildly LOL.
That's typical Lippert for you. $10.95 + $19.00 shipping for an O ring worth about 2 bucks.
