RV.Net Open Roads Forum: Class A Motorhomes: Bad Lippert O ring
 > Bad Lippert O ring
AikenRacer2
Aiken, SC
Posted: 11/14/22 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Never got a response from Lippert or any of the on line companies that makes custom o rings. Probably not interested in making one o ring. I did resolve the problem. I added a small washer to each of the 4 hold down bolts. This gave me more compression on the o ring. I think the bolts were bottoming out on the pump. Anyway, I now have it fixed with no help from Lippert!
k9-keno
PA
Posted: 11/14/22 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for posting this I have the same problem. I'll try the bolts but if not I have a hydraulic shop near me that has o rings. This is a common problem and Lippert would rather sell you a new 2k pump.
2007 Damon Daybreak 35.4ft Class A
2001 Georgie Boy 31ft Class C
2003 Coachman Auroa Gold Class A
1995 Coachman Santara Class C
2000 Coachman Pop-up
1988 Dodge Ram Conversion Van
dougrainer
Carrolton, Texas
Posted: 11/14/22 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
No response? I just went to LCI online store and put the o ring in my shopping cart. I did not order it, but it did not stop the process. Glad you found a solution, but I still think a $30 (including shipping) would have been worth the effort. Doug
Pbutler97
Midwest
Posted: 11/14/22 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think it would have been worth anything. Lippert sucks! Everything they make, distribute, or are involved with is low grade junk. Then they do everything possible to force folks into buying their service or replacement parts by making them as proprietary as possible then mark the Chinese junk up way more than its actually worth. Everything from $30.00 O rings to $900 12 vdc motors. They're a large part of the problem with the overall junk produced by the entire RV Industry.
