RV.Net Open Roads Forum: Tech Issues: DIY 50 amp to 20 amp pigtail
 > DIY 50 amp to 20 amp pigtail
Page of 7
Posted: 11/07/22 11:29am Link  |  Quote  |  Print  |  Notify Moderator
KnowNuthin wrote:
My original idea is officially axed... somewhere in the back of my brain having 50a running through an extension cord didn't seem like a good idea,
Mitch's idea works too... I already have the 50a - 30a dogbone...
Remember, you're not automatically pulling 50A through your ext cord. You only have the ability to, in the scenario you mentioned. If the "load" only takes say 2 amps, or whatever, that is what the cord "experiences." The danger mentioned is the "potential" to draw the theoretical 50A of current and not blow the breaker, thus heating up and damaging the weakest link in the chain.
There are a few options, not entirely clear without seeing your sub panel, but seems the easiest and safest no brainer is get a 30-20A pigtail and not ever touch the hot side of the box.
time2roll
Posted: 11/07/22 11:55am Link  |  Quote  |  Print  |  Notify Moderator
No issues with 600 watts.
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 11/07/22 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
The lite wire becomes a fuse if you use the 50 ampere's circuit. Failure in the heater could cause wire to melt down and create a fire situation.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 11/07/22 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
This could happen on a 15 amp circuit also.
Probably #18 wire in the cord.
LittleBill
Scranton, PA USA
Posted: 11/07/22 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
so do all you guys who have 15 amp circuits in your house, where your lamps are plugged in use a 1 amp circuit breaker to each individual lamp?
Posted: 11/07/22 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Your 50 amp should be a double pole breaker.
I think it is a bad idea for what you are thinking.
I would suggest getting thin breaker with two 20-amp breakers and installing a new receptacle. Some call breakers, wafer or tandem.
The short answer is yes it would however there is a danger
The longer answers #1: You need not DIY you can easily adapt from 50 amp RV to TT-30 and from there to a common 15 outlet (Why they always make it a 15 and not a 15/20 I will never understand)
in fact...
Here you are
But I'd not do that
I'd use a box that lets you put a 15 or 20 (Depending on the outlet) breaker in with the 15/20 amp outlet. You need to protect the smaller wireing
Your proper adapter would look like this
50 amp plug & pigtial== Box with 20 amp breaker---15/20 amp outlet---Tractor
Or use a 15 amp breaker and a 15 amp outlet
The breaker need not be teh "Square D" type you can use a "push to reset) if you have a box with enough room.
As you surmized one black (or red) wired is NOT connected.
toedtoes
California
Posted: 11/07/22 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
No, but anything that produces significant heat is put on a GFCI outlet or is connected via a surge protector with internal circuit breaker. But I admit I have a healthy fear of electricity.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Bobbo
Wherever I park
Posted: 11/07/22 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
I was going to type this very thing on reaching the end of the thread. You beat me to it. Every one of my 1/2 amp (60 watt) lamps is plugged into a 15 amp outlet protected by a 20 amp breaker. Yes, I am risking the 18g wire shorting out and melting creating a fire hazard. I don't care.
Bobbo and Lin
ktmrfs
Portland, Oregon
Posted: 11/07/22 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
EXACTLY!!! whole point is to make sure the wiring downstream of the breaker can handle the max breaker current in the case of a downstream fault. !!!!!
2011 Keystone Outback 295RE
ktmrfs
Portland, Oregon
Posted: 11/07/22 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
the lamps are likely using a 14 or 16 ga wire, entirely capable of handling 15 or 20A for a short period of time if the lamp were to cause a short. A 12Ga extension cord is NOT capable of handling 50A for any length of time.
Page of 7
