RV.Net Open Roads Forum: General RVing Issues: Camping at 27 degrees.
 > Camping at 27 degrees.
Page of 7
afidel
Cleveland
Posted: 11/14/22 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Veebyes wrote:
JMO with only a few nights experience in the 30s but RVs are not good places to be in cold weather. Out of the factory they are not made for it.
Cold air leaks in around slides. Walls are thin. Glass is single pane & radiates the cold. Without some serious post construction mods they are simply no up to dealing with the cold.
You can put up a good fight against cold but it will take alot of electricity & alot of propane.
Point the thing south & don't stop until you no longer see bridge freezing before road warnings or no snow blowers outside of Lowes or Home Depot.
Been using a trailer as a home office for going on 3 years now in NE Ohio, put some Reflectix in the windows and vent covers in the vents is the only mod I've made. It works just fine and when I was using a combination of propane and one electric heater I was going through a 20 pound bottle a week on average, now that I've upgraded my electric at home to 50A and run 3x electric heaters I barely use any propane. The one caveat is that the water system is winterized and the temp is allowed to go down to 45 when I'm not actively using the trailer, I've got enough foodstuff in that I don't want it to freeze and it takes too long for the electric heat to recover if it gets too cold.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
dedmiston
Coast to Coast
Administrator
Posted: 11/14/22 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sooo... Belize or Guatamala, somewhere down there? [emoticon]
I see those "bridge freezes before the rest of the world does" signs just about everywhere in the U.S. except maybe Florida.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
spoon059
Just north of D.C.
Posted: 11/14/22 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
All things equal the relative humidity drops with increased temperature. This is why the cold window or a cold beer sweats. The air in proximity cools and becomes more humid to the point the moisture actually precipitates out of the air and onto the item.
Same effect no matter the heat source.
Unvented combustion of any hydrocarbon produces moisture. Wiki has the chemistry if someone needs to see it.
I have no interest in the chemistry. I've camped in the cold weather using electric heat and I've camped in the cold weather with propane heat. Electric is cheaper. Electric has a lot less condensation buildup. Electric is quieter. Electric is more even temperature.
By all means, do whatever you want to do with your camper and your money. I was replying to the OP who was looking for real world advice.
2015 Ram CTD
2015 Jayco 29QBS
blt2ski
Kirkland, Wa
Posted: 11/14/22 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry,
Yes had all 6 of us in the trailer. Not mention two Alaska malamutes at 80 and 120 lb.
I'm sure all of us breathing helped to make more moisture in a 25' TT. None less, all the things mentioned would also add to the amount of moisture on the windows etc.
Marty
2014 Chevy 1500 Dual cab 4x4
MFL
Midwest
Posted: 11/15/22 08:25am Link  |  Quote  |  Print  |  Notify Moderator
blt2ski wrote:
Jerry,
Marty
Hey Marty...those are some big pups, a trailer load, all-in! [emoticon]
Here's a pic of my snowmobiling, dirt biking, canyon racing buddy, with his Alaska Malamute, to give other members, an idea of the size of these gentle giants.
Jerry
blt2ski
Kirkland, Wa
Posted: 11/15/22 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry,
Have a picture somewhere of "floof the bear" with my at the time 15 month old grand daughter. Mr Bear is OVER 200 lbs
They can get really BIG!
My two were small!
Marty
free radical
Canada
Posted: 11/16/22 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
To toss my 2c in.
Ive been using Espar diesel heater in my TC and its totaly dry heat,no condensation.
Used couple galons a week in Northern Alberta.
Bobbo
Wherever I park
Posted: 11/16/22 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
On the Espar, is the combustion chamber inside the living space of the TC, or outside of it?
Bobbo and Lin
Posted: 11/17/22 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Pffft, real world advice is overrrated...you've been a member of rvnet long enough to realize that! LOL
Cheers!
On a similar note, I've really been wanting to try one of those China bomb little diesel heaters for my snomachine trailer.
As I use a Buddy heater sometimes if need to warm it up on the mountain or a milkhouse heater and box fan to dry everything out at home after riding (since it doesn't get below freezing much here).
If only I needed to do that more than a couple times a year....sigh...
DallasSteve
Posted: 11/17/22 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
We were in far South Texas in February 2021 when the big freeze hit and the electricity went out and Ted Cruz went to Cancun. I think it got down to the 20s, but I'm not sure. I had 2 propane tanks in a 32 foot Class A, but I think I was down to one tank. We went through that last tank in a few hours that night, and I didn't have the thermostat set that warm inside. About 3 AM I woke up and the furnace was blowing cold air. But fortunately we had 2 electric heaters and our area didn't lose electricity so it didn't get too bad. If we had lost electricity we would've been sleeping in the Jeep with its motor and heater running. The point of this rambling is you can run through propane fast on a cold night.
* This post was edited 11/17/22 06:57pm by DallasSteve *
Page of 7
