RV.Net Open Roads Forum: General RVing Issues: Camping at 27 degrees.
 > Camping at 27 degrees.
Page of 7
shannon62
texas
Posted: 11/09/22 09:15am Link  |  Quote  |  Print  |  Notify Moderator
We are new fulltimers,with 2007 bounder class a 38v. We are trying to stick around sw p.a. till thanksgiving, they are calling for low around 27 degrees. We have ducted heat,2 furnaces,with supposed basement heat so say's owners manual. I am going to disconnect from shore water and just use fresh tank,keep heat on 70,leave luggage lights on (1156) in wet storage,leave gray water open as always & empty black then shut and add antifreeze.Should that be good enough ?Thanks Shannon.
CA Traveler
The Western States
Posted: 11/09/22 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Manuals are often generic so verify what they state and check that everything works. For 2 weeks out best to plan for lower temps. Open all cabinets and areas inside with water pipes. Doubtful that low wattage 1156 bulbs willl provide adequate heat. Consider 120V lights.
2014 Grand Cherokee Overland
Bob
schlep1967
Harrisburg, PA
Posted: 11/09/22 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you are doing everything right. One thing that can get you are air leaks. Go out at night and with the lights on in the basement, look for any light escaping. Get those holes blocked with rags or tape. If the air leak is close to a water line it can easily cause it to freeze.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
pianotuna
Regina, SK, Canada
Posted: 11/09/22 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Shannon62,
This thread has some excellent advice.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24160748.cfm
Regards, Don
ReneeG
Meridian, Idaho
Posted: 11/09/22 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Keeping your furnace at 70 will go through a lot of propane. We keep ours at 55 and use about 1/4 tank per night. As long as it heats up in the day, you won't have to worry about the pipes freezing.
Edit- i said 55 because we ran a test on how much propane would be used ifvwe ran the heater at night.
Last camping trip, it was 26 the first morning and 21 the next. We did not run the heater at night. First thing in the morning, we turned in tbe Heater Buddy. The daytime temps were 65, so we didn't have any issues.
* This post was edited 11/09/22 03:32pm by ReneeG *
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Posted: 11/09/22 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
You have nothing to worry about, looking at the Pittsburgh forecast through beginning of December. Except maybe the garden hose freezing at night, which is easy to unhook and run off your tank.
If the temp is getting well above freezing during the day and only into the mid 20s at night, unless you literally have a camper water line that is totally exposed to the atmosphere, AND the daytime temps are staying below freezing.
Think about it this way. Takes a few hours to make ice cubes in a freezer and that is around 0 deg F.
Turn off your luggage lights, they won't add enough heat to do anything.
Don't bother draining gray and black. Again, a HUGE ice cube isn't going to freeze up unless it's below freezing for days. No AF needed in the P traps either.
If you don't believe me, take a bottle of ambient temp water, the first day it is getting below 32 at night, put it on the outside step and see how frozen it isn't the next morning.
Note, what I'm saying is not applicable to just leaving the camper for days unattended and hoping it doesn't get colder than forecasted.
dedmiston
Coast to Coast
Administrator
Posted: 11/09/22 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
We camp down in the 20s all the time. The issue is how deep into the 20s and how long will it stay that way?
Dipping down that low overnight and freezing the dog's water bowl is no big deal. If it stays in the 20s all day though, then it's serious.
We just keep the living quarters warm enough to be comfortable, which keeps the underbelly warm enough to prevent freezing.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
JimK-NY
NY
Posted: 11/09/22 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds really excessive. I have camped with the daytime highs in the upper 30s and the lows about 20. I also turn the heat off at night and sleep under a couple of large blankets. I don't take any special precautions. It takes a long time to freeze tanks hard enough to do any damage. If you are worried try a half gallon of antifreeze in each tank.
JUSTWORK
east coast
Posted: 11/09/22 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Below freezing unhook water hose unless heated, fill fresh water and unhook any sewer hoses. store hose in heated storage. As long as your furnace is running and your underbelly is heated your good.....
blt2ski
Kirkland, Wa
Posted: 11/09/22 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Then theirs idiots like me that went into the mountains and used my TT as a ski hit! 0-15F night vs day at times.
Reality, do what you doing. I never turned the heater off, kept it around 70f. Then again, you do not appear to have 4 kids from 6 months-18yrs with you over the 10+ yrs I did this.
If you do this alot, find the manual drain lines in the main lines, remove them! Water will freeze up, and you will not have water beyond that point. For me it was bathroom and hot water heater at rear of trailer. The front kitchen had water.
If you have exposed gray and black tanks, the may freeze, if temps are lower than freezing for a few days. They usually have room to expand, not a big deal.
I found having door vent covers to be a good thing when it snowed. Even with 2-3' of snow on the roof, we had ventilation. With out we had none.
My 02
Marty
2014 Chevy 1500 Dual cab 4x4
Page of 7
