RV.Net Open Roads Forum: Travel Trailers: Removal of Refrigerator Roof Vent
 > Removal of Refrigerator Roof Vent
LynnandCarol
Rockport, TX
Posted: 11/12/22 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone removed the Refrigerator Roof Vent? We upgraded to a residential Refrigerator (Apt. Size) and no longer have a need for it. Going to be doing Roof Resealing soon and would like it gone. Not sure how to remove it, or what size hole would be left to cover/seal.
TurnThePage
North ID
Posted: 11/12/22 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
It sure comes in handy for routing solar panel/wifi/network cables into the RV. I think it would be a lot more trouble to remove it than seal around it. JMHO
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
98coachman
North Idaho
Posted: 11/12/22 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
Piece of cake! 4 screws hold it down to the housing and then probably twenty screws holding housing to the roof, there will be some caulking on top of the screws, but easy to remove. The opening below is probably about 8 x 24. You can attach some cleats to the side of the opening and put some plywood over the opening and then reseal the roof. Good luck with the repair.
Bill
agwill
enosburg falls, vt
Posted: 11/13/22 04:07am Link  |  Quote  |  Print  |  Notify Moderator
I would keep it. The fridge still needs air flow to work correctly.
al
JBarca
Radnor, Ohio, USA
Posted: 11/22/22 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Good point.
If you seal up the roof, while the lower side vent is still there, the back of the home fridge is buried in a dead space hole at the top. Come the hot days of summer, the heat off the coils in the back of the compressor fridge are stuck in a hot air blocked space. Hot air rises, and it can't get out.
Something to think about.
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
LMHS
NM
Posted: 11/22/22 10:15am Link  |  Quote  |  Print  |  Notify Moderator
I have a residential refrigerator in the truck camper, kept the rooftop vent. The refrigerator needs the air circulation (cooling tubes are in the sides and top of the refrigerator) AND I have cables running thru the vent for the inverter.
I have a 13cf upright freezer and stacked two 4.4Cf dorm type refrigerators in my bus. These both have a vent at the back to allow heat to dissipate. Residential units do have heat build up and few refrigerators have the old style "radiator coils" on the back. They tend to be build against the metal skin of the appliance cabinet. In the case of freezer doors (both dedicated and ref/fzr combo units) a "loop" of tubing is run around the door opening to help in preventing up icing at the gasket. This is why there is supposed to be a 2 inch (or more) air space on the sides and top of residential refrigerators and upright freezers. Keep the roof top vent.
