NuttyKev
NWA
Where can I find a replacement for this exact switch board. I looked at the manufactures website and they dont seem to list them. I did a google search and cant find it. Ebay has a few, but not the same layout as mine.
![[image]](https://i.postimg.cc/ht1CZfyL/2022-11-13-13-12-58-921.jpg)
last
edited 11/14/22 04:44pm by an administrator/moderator *
View edit history
What is not workign properly?
It might not be the switch panel unless it is physically broken.
enblethen
Moses Lake, WA
If you need switches, JR RV products have them.
Have you contacted American Technology Components?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Carrolton, Texas
https://www.atcomp.com/
If you are talking about the monitor panel. Rarely do they go bad. It is usually a sensor or wiring fault. All other parts on the panel can be found easily. switches may not be same color but you can find them in red or orange. Doug
BB_TX
McKinney, Texas
The rocker switches should be replaceable. The little membrane switches and lights are probably circuit board mounted and a specially manufactured item, maybe obsolete if an older RV. I would call American Technology Components.
rk911
DuPage County
when all else fails try Colaw RV Salvage.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Pbutler97
Midwest
I think those are made in batches per the RV manufacturers specs at the time and once the production run is gone, they're gone.
NuttyKev
NWA
If you look at the AUX button, youll notice its bubbled out. It burned up. So the whole board is bad now. Technically the all the rocker switches are still good. I looked at American Technology Components website. They dont list any boards, just individual switches. Ill look up the other sites mentioned, thanks.
enblethen
Moses Lake, WA
Check this Panel out.
This place may have more. I saw a circuit board that looked similar.
dougrainer
Carrolton, Texas
odds are it is a KIB circuit board. What you can do is search for a KIB panel that has the similar button tank readings. If you find one that has 2 Aux tanks, it will probably fit you just will not use the 2nd tank. Doug
