RV.Net Open Roads Forum: Roads and Routes: Tire chains in Califdrnia
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > Tire chains in Califdrnia
dennych1
Long Island New York
Posted: 11/15/22 08:51am Link  |  Quote  |  Print  |  Notify Moderator
After 2023 truck camper rally in February I will travel and explore California. I will be towing my Jeep behind my truck camper. Do I need to carry snow chains for truck and Jeep which are 4wd. Are they mandatory in certain area. I could use some info on this.
Thanks
Dennis
enblethen
Moses Lake, WA
Posted: 11/15/22 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Here is information from Cal Trans
Read through them for yourself. I would say you have to carry them plus install depending on level of requirement.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CA Traveler
The Western States
Posted: 11/15/22 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Likely the Jeep will require brakes. Plus chains when required. Perhaps for other states also.
2014 Grand Cherokee Overland
Bob
time2roll
Posted: 11/15/22 11:25am Link  |  Quote  |  Print  |  Notify Moderator
afaik if towing and chains are required at any level you will be required to chain a drive axle of the pulling vehicle and one axle of the vehicle behind. If you have two drivers it is possible to separate and continue in the 4WD OK conditions.
There will be a sign or check point when required. You can continue past the sign subject to a citation depending on conditions. A check point will not allow you to continue until vehicle equipment is in compliance.
675w Solar pictures back up
JRscooby
Indepmo
Posted: 11/15/22 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard some flatlanders bought chains before going into area where might be needed, carried for while, than returned to get most of money back (Sounds like a rent thing to me). But all I talked to where running 22.5 or 24.5 wheels, might not be available in your size or area. Might look into it though.
dennych1
Posted: 11/15/22 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
So even though I have 4wd I might need chains
time2roll
Posted: 11/15/22 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
The likely hood depends on where you are going and if the trip can be delayed a few days after a storm.
If you must get to Lake Tahoe while it is snowing there is a great chance chains are required. If near the coast or central valley very unlikely to ever need chains. The interstate passes are usually cleared and melting within a few days.
CA snow is often the heavy wet sloppy stuff that makes any hill difficult. Very different from the crisp dry snow in other areas.
camperdave
northern, California
Posted: 11/15/22 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
If you are towing, yes. If you can disconnect and drive them separately, then no. But you still legally need to carry the chains with you even though you won't need to install them.
In my experience, the major roads in Ca go from R2 (2wd with chains, or 4WD with snow tires) direct to closed. I don't think I've ever seen an R3 (everything needs chains) situation.
But I'm a very occasional snow goer, I live on the coast.
2004 Fleetwood Tioga 29v
ferndaleflyer
everywhere
Posted: 11/15/22 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
That must be what those funny looking things hanging in my barn are that go around the wheels----CHAINS. In all my skiing days I have never used them but suspected that was what they were for.
Alan_Hepburn
San Jose, Ca, USA
Posted: 11/16/22 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Had a CHP officer explain it as: if the weather is bad enough that you need to put chains on a 4WD with good snow tires then you need to stay home.
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
