RV.Net Open Roads Forum: Tech Issues: Safety: Microwave Fire!
 > Safety: Microwave Fire!
thewayweroll
Missouri
Posted: 11/15/22 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Folks,
The kids have moved out. The wife & I have been able to spend more time in our TC. I installed a microwave when we first bought our used Lance. It is a 700 watt so we can run it off the inverter when needed.
I had got into a habit of putting a piece of paper towel underneath the plate to absorb any extra moisture from cooking. There was a piece left inside the microwave when I was doing some testing on a new 30 amp plug in I installed at the house. Long story short... I ran the microwave with nothing inside of it. I didn't realize there was a piece of paper towel inside & even if I did it wouldn't of changed anything. Well, that all came to an end.
While the microwave was running I went outside & quickly smelled smoke...****! Ran back in & the Microwave ignited the Paper towel. My assumption is that if you have food inside with a paper towel than the energy is not all going towards the paper towel & that's why most get away with it. However, if there is nothing inside the towel gets 100% of the energy. Yes, there was an active fire inside the small 700 watt microwave. Needless to say I will no longer be using any paper towels inside anymore.
I just wanted to share this experience with you all.. Stay safe my friends!
2007 Ford F-350 XLT DRW 13K GVWR|Front Hitch|TorkLift 20K 48"
1994 Lance 990 2.5Kw Onan|840 Watts Solar w/220Ah AGM
profdant139
Posted: 11/15/22 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! That is surprising, since using a micro with a paper towel under a dish ordinarily does not heat up the paper. Thanks for the tip!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
opnspaces
San Diego Ca
Posted: 11/15/22 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
I've heard about paper towels catching fire before. But until now I figured it was probably an urban legend. Glad you aren't posting that your camper or truck was damaged.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
time2roll
Posted: 11/15/22 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
NEVER do that
675w Solar pictures back up
Ed_Gee
Central Oregon coast
Posted: 11/15/22 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
I had heard long ago that it was hard on the microwave 'tube' to operate it without a 'load' for the power so never thought to operate it without some food or drink in it.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
2oldman
NM
Posted: 11/15/22 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
If you want a real thrill put something metal in there.
thewayweroll
Missouri
Posted: 11/15/22 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Fire cracked it.. Glad it wasn't worse!
thewayweroll
Missouri
Posted: 11/15/22 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for Reading!
thewayweroll
Missouri
Posted: 11/15/22 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
I would've assumed an urban legend too until It happened. Like a lot of people in life... If you don't see it it must not be true. We are lucky it didn't go any further than the small fire inside the microwave
thewayweroll
Missouri
Posted: 11/15/22 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
NEVER do that
Too late! [emoticon]
