RV.Net Open Roads Forum: Tech Issues: Safety: Microwave Fire!
 > Safety: Microwave Fire!
2oldman
NM
Posted: 11/16/22 09:08am Link  |  Quote  |  Print  |  Notify Moderator
The font is weird and blue, and the quote has changed. Strange.
jaycocreek
Idaho
Posted: 11/16/22 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I use a paper towel or a paper plate with food on it, all the time and never have had an issue..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
thewayweroll wrote:
JimK-NY wrote:
thewayweroll wrote:
JimK-NY wrote:
Maybe you need to stop using the microwave and leave it to your wife.
My wife doesn't "Test" things like I do. That's my job. I'm happy it happened to me & not the wifey.
Do you also jump in front of a train to test if it will stop in time? Microwaves have been in use for decades. There is nothing new or to test about avoiding running an empty microwave. They are not idiot proof but they do require opening the door and presumably adding material in order to run. If you ignore the basics, why did you also leave the microwave running with just a piece of paper in it?
I guess next time you can test what happens if you run the microwave with a metal container. Don't bother to warn us about the outcome.
Shall I also tell you not to eat yellow snow? Let's not throw sarcasm in this thread! You're being unreasonable here.
I'll explain it again... I didn't know there was a piece of towel in the microwave. I wanted to run all the appliances in the RV to test my 30 amp outlet. I wanted to see if the new installed 30 amp would handle all the RV loads w/o tripping the breaker.
If this is something you find not reasonable then this thread is simply not for you. You must be one of those "fool proof" people that have made no mistakes. At least I'm willing to share mine. [emoticon]
He pretends he is....
Thank you for sharing. I didn't know that.
NamMedevac 70
Reno
Posted: 11/16/22 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Glad you enjoyed my comment Missouri. You are welcome to more anytime.
NamMedevac 70
Reno
Posted: 11/16/22 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Same here for over 25 years now with no issues. Food instructions often say to cover with a wet or dry paper towel depending on what's cooking.
Sport45
Not far enough from Houston, TX
Posted: 11/16/22 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Yes, the problem was not the paper towel. There is no issue with covering food with a paper towel in a microwave. I’ve never put a paper towel under a plate but see no problem with that either. The issue here was entirely due to running the microwave empty. Anything on the loose piece of paper was subjected to all the wattage and quickly hit ignition temperature.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
naturist
Lynchburg, VA
Posted: 11/16/22 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
thewayweroll wrote:
I ran the microwave with nothing inside of it.
NEVER do that
X2
Not surprised it caught the paper on fire. You are lucky it didn't blow up the whole thing.
Posted: 11/16/22 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
2112 wrote:
There is a large sign in bold letters on the paper towel dispenser saying "Do Not Use In Microwave. Fire Hazard". Our theory is they do not separate staples and other small medal items while recycling.
yes the story is "Metal Shavings".
Something most folks do not know is some pieces of metal are more dangerous in a microwave than others.. Depends on the size of the piece and before you ask.. I don't know.
3 tons
NV.
Posted: 11/16/22 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Well about a dozen years ago I accidentally dropped my cheapo flip-phone into the pool…My attempted fix was to put it in the microwave for a short time to dry out the water….
Trust that I won’t ever do that again - lol
3 tons
thewayweroll
Missouri
Posted: 11/16/22 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Bingo!
2007 Ford F-350 XLT DRW 13K GVWR|Front Hitch|TorkLift 20K 48"
1994 Lance 990 2.5Kw Onan|840 Watts Solar w/220Ah AGM
