RV.Net Open Roads Forum: Easy way to raise trailer's nose while hitched in campground
 > Easy way to raise trailer's nose while hitched in campground
profdant139
Posted: 11/15/22 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Fairly often, we pull into a campground space, only to discover that the nose of the trailer is just a little low, because of the way the pad is graded.
Rather than unhitch the trailer and raise the nose with the jack (which we prefer to avoid when we're just overnighting), here is an easier alternative: just raise the back of the tow vehicle by putting Lynx Levelers or some wood under the rear tires.
It's simple, but it works, as long as the nose is not way too low.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
RICK-ards Red
Ontario
Posted: 11/15/22 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have seen people put wood down then back the truck onto the wood to raise the hitch. Seems to work. I have just left everything hooked up, WD, safety chains etc but undid the hitch pin and raise the tongue of the trailer. Then in the morning just lower the tongue onto the ball and leave , works for me.
2017 Coachman Catalina 25RKS
2015 GMC Sierra 1500 - Kodiak edition
Home Skillet
Pearland Texas
Posted: 11/15/22 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Put air bags on the tow vehicle, along with the onboard air compressor. You can raise or lower the rear of the tow vehicle with the remote control.
LINK
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
BarabooBob
Baraboo, WI
Posted: 11/15/22 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
We just set up as usual and unhook. I just don't move the truck if it is an overnight and run in the morning stop. It only takes us about 5 minutes to hook up and do our safety check. By the way, we don't use a weight distribution system because our trailer is way below what the truck can actually tow. One of the advantages of towing a lightweight trailer.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Mike134
Elgin, IL
Posted: 11/15/22 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Since I use the tongue jack to lift the truck and trailer 6" to put on the equalizer spring bars, I just use the tongue jack and lift the trailer and truck the few inches needed to level it.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
opnspaces
San Diego Ca
Posted: 11/15/22 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I also just use the electric tongue jack to lift the tongue and the back of the vehicle as a unit. For extreme lifts I have just opened teh coupler and jacked it up.
But then again I never thought about just backing onto levelers. I might try it next time out as I always have a ton of room where I'm going.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
valhalla360
No paticular place.
Posted: 11/15/22 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
^^^ This.
Assuming "a little" is only 2-3 inches, just run the trailer jack up 2-3 inches.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
NamMedevac 70
Reno
Posted: 11/16/22 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Your lynx levelers are very cost efficient. My electric tongue jack failed me at night in freezing rain, so I now use only hand crank jack. The exercise is good for me and warms me up in no time. P.S. The hand crank for my electric tongue jack was misplaced a long time ago. Cheers to the brave.
valhalla360
No paticular place.
Posted: 11/16/22 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Electric, manual...still the simplest solution. Manually cranking it up 2-3 inches should take less than 30 sec.
Also, if you use blocks under the rear truck axle, you are likely to get more bounce in the trailer as the truck springs are supporting the front of the trailer.
If you put the trailer jack down, the truck suspension is isolated from the trailer.
JRscooby
Indepmo
Posted: 11/16/22 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Why not both? Run TV rear tires on blocks, then use jack tongue jack to hold it still, stop bounce?
Something to think about; One evening we where set up, and storm rolled in. When the tornado warning started my wife, and wife from next site got in cab, other guy and I sat on tailgate. On the way we picked up another couple. They could not drive to restroom/storm shelter because still hooked up.
