RV.Net Open Roads Forum: Easy way to raise trailer's nose while hitched in campground
 > Easy way to raise trailer's nose while hitched in campground
mdcamping
CT
Posted: 11/16/22 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
yup most RV's are anchored down to their sites where it would take time to move out in an emergency like you described. You did the right thing looking out for your camping neighbors. [emoticon]
If I'm not disconnecting the truck from trailer, I will crank the tongue jack a few inches if I find the trailer way-unlevel. Most times I drop the trailer jacks also as I find the trailer bounce annoying.
Mike
2022 F-150 3.5 EcoBoost 4X4 Supercrew GCWR 19,500 157WB
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
valhalla360
No paticular place.
Posted: 11/19/22 08:52am Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
valhalla360 wrote:
Electric, manual...still the simplest solution. Manually cranking it up 2-3 inches should take less than 30 sec.
Also, if you use blocks under the rear truck axle, you are likely to get more bounce in the trailer as the truck springs are supporting the front of the trailer.
If you put the trailer jack down, the truck suspension is isolated from the trailer.
Why not both? Run TV rear tires on blocks, then use jack tongue jack to hold it still, stop bounce?
Something to think about; One evening we where set up, and storm rolled in. When the tornado warning started my wife, and wife from next site got in cab, other guy and I sat on tailgate. On the way we picked up another couple. They could not drive to restroom/storm shelter because still hooked up.
What do you see as the gain if you do both? It seems like just an extra step with no benefit. Given that 95% of campers have electric jacks, it's 10-20 second of pushing a button.
If you just roll off the blocks with the jack down just enough to stabilize it, the jack will then take the full load and drag along... so you aren't driving to the bath house in the event of a tornado.
Of course, any time we've have a tornado warning, it's usually simpler and quicker to walk to the bathhouse, rather than drive.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JRscooby
Indepmo
Posted: 11/19/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Well, if when you put your drives on blocks to level, then worry about the trailer bouncing, running the jack down will stop the same amount of bounce, hooked up or not. Sure, need to run it up before you move.
What education I have is limited. When I went to school a new paragraph indicated a change in topic. IMHO the fact that sometimes tornados happen, and sometimes it is a distance to storm shelter is a reason it might be prudent to unhook, have the TV ready to move
Bobbo
Wherever I park
Posted: 11/19/22 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
If I have not unhooked and I have to run from a tornado, the trailer goes with me because I haven't unhooked.
Bobbo and Lin
JRscooby
Indepmo
Posted: 11/20/22 07:16am Link  |  Quote  |  Print  |  Notify Moderator
LOL Well, if you are out in open country, where you can see tornado some distance away, and the road goes right direction, this might be a option. But even if it misses your site after you leave, how much damage is done when you drive off with hoses and cords tied to ground?
Now if you are in most of the country, where tornados happen, you get a watch that covers a wide area, several counties. Then once tornado is seen, radar or eyes, they broadcast the location and direction of travel. Unless you are behind it, it is a good idea to get close to a shelter. By close, I mean if there are more than a couple of people standing in bathroom doorway, and it's half mile to horizon go on inside. By the time you see it, you may have less than 30 seconds to cover your donkey. A jam-up in doorway can be fatal.
Run from it with a trailer? First in much of the country roads around CGs don't go far in straight line. So here you go Indy caring your snot in a panic. Who else is at risk? (You, Darwin called) Then there is the fact tornados often change directions at random, and often form others that can go other directions.
In short, hear the watch, make sure you know where the shelter is. Once the watch changes to warning, walk or drive, depending on which is quicker, to the shelter.
valhalla360
No paticular place.
Posted: 11/20/22 08:08am Link  |  Quote  |  Print  |  Notify Moderator
But why bother doing both. Once you run the jack up, it's level and stable.
As far as paragraphs, apparently your education is limited. If you are in a mad rush to get away from a tornado and just pull away off the blocks, the jack will drop down and dig in. Either way blocks or no blocks under the rear axle, you have to pull up the jack. Seems pretty straight forward.
I already addressed the issue of tornados in reality, is you can generally walk to the storm shelter quicker than driving.
Still waiting on some advantage to doing both jack and blocks.
Bobbo
Wherever I park
Posted: 11/20/22 09:15am Link  |  Quote  |  Print  |  Notify Moderator
The same risks apply without the trailer.
As rare as tornadoes are, I will risk that damage. All I will risk is the power cord. I don't have the sewer or water hose hooked up. Never do. I fill the fresh water tank and use it. I dump then put the dump hose back up.
Every one of those things also apply when the trailer is not attached.
JRscooby
Indepmo
Posted: 11/20/22 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Maybe. But if you hear the warning, and know the bathroom is 1/4 mile away, you have a good chance to drive that distance. Most likely you will not be hit, because tornados only hit a small percentage of the warned area. So nothing is damaged, nobody hurt. But if the CG is hit, your best chance to escape injury is in the strongly built building.
Bobbo
Wherever I park
Posted: 11/20/22 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Which is within running distance. It is faster to hoof it than to try to start the tow vehicle and drive to it.
JRscooby
Indepmo
Posted: 11/20/22 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
LOL. In my 20s I might of been able to run a 1/4 faster than I could get in and drive. I know my wife could not the day I met her 37 years ago, and doubt I could off. Now I can walk a mile in 20 minutes most days. Run? Not 100 yards. But you do you, and be glad you can.
