RV.Net Open Roads Forum: Dinghy Towing: Brake buddy compressor power draw
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Supplemental Braking Systems
 > Brake buddy compressor power draw
mcewena
Canada
Posted: 11/16/22 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Hi, How much power should a brake buddy classic draw during the compressor cycle? With the engine running on the toad and the alternator putting out 14.1v the compressor cycle drops it down to 11v. Without the engine running the compressor takes it below the 9.5v shut off so it’s not usable. It’s a Miata with a fairly small (newish) battery but it’s hard to fathom the BB compressor taking more than the car starter.
Tia
LadyRVer
Posted: 11/16/22 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know the "draw" answer, but we had to have a separate line/plug run to the battery. The 12 volt receptacle in vehicle was not enough for the BB.
mcewena
Canada
Posted: 11/16/22 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
There’s a separate adapter in the trunk (god knows why), it’s wired directly to the battery (also in trunk) and it does the same thing from there. BB got back to me saying it’s normally 7-9 amps but older units can spike up to 13-14.
I think the load is just too much for the tiny U1R battery. I either need to replace the BB, draw power from the RV hitch plug or see if I can squeeze a higher capacity battery into the trunk.
