RV.Net Open Roads Forum: The GEO Method and Space Heaters - Thoughts?
 > The GEO Method and Space Heaters - Thoughts?
Page of 6
Baja Man
Inland Empire, CA
Posted: 11/16/22 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Preparing for a week long trip. It will be approx. 300 miles one way to our destination.
1.
I wanted to take this driving opportunity to clean my RV holding tanks.
I was considering using the GEO method (minus Chlorine). My goal is to cleanse inside of tanks, especially black tank, and perhaps coat the insides with the slippery water softener (Calgon).
I would fill each tank half way (Gray and Black) with Calgon and Laundry detergent and then dump once we reach our destination.
Are other methods to accomplish my goal of clean tanks.
Thoughts?
2. Space heaters. Propane heaters use quite a bit of propane. It appears it will dip in to the high 30s-low-mid 40s during our stay. I have two 30# propane tanks.
Are space heaters safe to use or what other methods can be used for my family to keep warm AND safe?
NOTE: We are warm weather campers, so we have little experience in colder temps.
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 Trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
ReneeG
Meridian, Idaho
Posted: 11/16/22 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have no idea about the tank cleaning, but have heard of it and makes sense.
As for the low temps, wear warm pajamas, lots of blankets and wear socks to bed. It shouldn't get that cold inside at night to have to run a heater, but worse case, set your thermostat to 40 and it won't kick on that much but just enough. Use your propane space heater during the morning until it warms up and bake cinnamon rolls or biscuits every morning. After baking, turn off the oven, then open the door to heat up your space with the residual heat. Now I know why I gain weight on cold weather camping trips!!
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Tiger4x4RV
Inland Empire, Southern California
Posted: 11/16/22 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
For heat, my favorite method these days on a trip like that would be to stay at a place with electrical hookups and use a small portable electric heater. Or use a propane heater and turn it off when going to bed. At the temperatures you describe, you and your RV plumbing won't freeze. Good long undies and lots of blankets and sometimes even a knit hat take care of night heat needs safely.
I never run either propane or electric heaters while I am asleep.
Have a great trip!
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
Boon Docker
Posted: 11/16/22 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
"I would fill each tank half way (Gray and Black) with Calgon and Laundry detergent and then dump once we reach our destination"
I always put 1 cup of Galgon in the tanks before using, has worked good doing that way.
What you are doing should work good as well.
toedtoes
California
Posted: 11/16/22 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
For heat, if you have electrical hookups, a space heater with remote control works great.
The remote allows you to adjust the temp without having to get out of bed - really nice.
If no electrical hookups, I use a Mr Heater and turn it on before I go to bed to warm up the RV. Then I turn it off during the night. I turn it back on in the morning to warm things up again. As I have dogs, I never liked putting it on the floor, etc. Instead I set it in the stainless sink - that keeps it away from flammable items.
Good quality bedding helps a lot too. And don't forget warm slippers - heat rises and the floor of an RV can cold.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
ferndaleflyer
everywhere
Posted: 11/16/22 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a DP and spent a week at pigeon forge and this past weekend, 3 days, at a racing event. I ran the hot water heater, cooked on the cook top, and ran the furnace all the time and it cost me less than $40 to refill the propane tank today. At both events it was colder than what you mention. I am not going to be uncomfortable, miserable, to save $40.
time2roll
Posted: 11/16/22 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1200 watt radiator style heater that does fine to about 35 degrees. Otherwise the furnace runs as needed.
Getting the holding tanks extra clean is overrated. Dump when full or when done camping.
675w Solar pictures back up
ktmrfs
Portland, Oregon
Posted: 11/16/22 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
heat:
we set the thermostat to 50F at night, put on a quilt.
Catalytic propane heaters are claimed to be safe, many have a low oxygen sensor. It is unvented so you will put about 1 gallon of water into the air for every gallon of propane you burn. So if your in a place with low relative humdity, it helps, if your in a place where RH is already high, expect wet windows. Since we usually winter camp in places with high RH, coupled with use of stove, oven, and wet clothes, we pass on the unvented heaters.
There is always the possibility of Carbon monoxide with an unvented heater. CO is deadly, and will give you NO warning if your lucky you survive.
2011 Keystone Outback 295RE
pianotuna
Regina, SK, Canada
Posted: 11/16/22 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Replace any 120 volt outlet in the RV if intending to use it with an electric heater.
I use 2 oil filled heaters. They have 3 possible settings. I use them on the 2nd highest.
When it is TRULY cold, I use an autoformer to support the voltage.
Real power (heat) output varies by the square of the voltage.
100 x 100 = 10000
120 x 120 = 14400
That works out to about 31% extra heat.
Regards, Don
Pbutler97
Midwest
Posted: 11/17/22 01:34am Link  |  Quote  |  Print  |  Notify Moderator
I guess if you need squeaky clean holding tanks carry on, its your time and money. They'll at least be nice and clean until your next morning constitutional, then rinse and repeat.
Page of 6
