RV.Net Open Roads Forum: The GEO Method and Space Heaters - Thoughts?
 > The GEO Method and Space Heaters - Thoughts?
Page of 6
pianotuna
Regina, SK, Canada
Posted: 11/23/22 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Use the best quality you can find with screw terminals. My replacement outlets are all 15 amp.
The "extra" outlets for my two auxiliary shore power cords are 15 amp, and 20 amp with appropriate wiring.
I'm set up to use the OEM 30; add on 20; and add on 15 amp.
While you are at this, take the time to tighten all the connections in the breaker panel. Some of mine took one whole turn.
Regards, Don
Baja Man
Inland Empire, CA
Posted: 11/23/22 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Would seem easier at this point to just use your furnace and a little more propane…
I agree.....since I'm leaving on Friday, I don't have the time to do the upgrades. I'll run the propane furnace this time and see about the outlet upgrades at a later time.
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 Trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
Baja Man
Inland Empire, CA
Posted: 11/23/22 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone.
Considering I am leaving this Friday, once I return from my trip I'll come back to this thread and see about making the upgrades.
Baja Man
Inland Empire, CA
Posted: 11/23/22 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs wrote:
Baja Man wrote:
So how about these....assuming a box can be installed.
If box will not fit, where can the higher quality RV specific receptacles be sourced? How will I know they are better than what I have? The ones I have seen appear to require a tool to install wires in rear. They also appear to be of same quality as I have now (stab style).
Commercial grade outlet
that's what I have used however do NOT install the 20A outlet on a 15A circuit!!!!!! against code, use the 15A outlet, you don't want to be able to try to run something with a 20A plug on a 15A circuit.
There is a "shallow" retrofit plastic box that in my trailer was shallow enough to fit in the existing wall.
Yes on the 15amp...the pic was just for reference for commercial grade
rhagfo
Portland, OR
Posted: 11/23/22 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Well dad was a firefighter so he hated electric space heaters as do I. That said we heat electrically, I installed RV Comfort Systems “Cheap Heat” an electric heating element unit that adds on to our furnace. We can heat with gas or electricity with a flip of a switch. If you have a 30 amp service you can get 1,800 watts of heat on a dictated 20 amp circuit. If you have a 50’Mp service you can get 5,000 watts of heat on a 30 amp 240 volt circuit. All is UL listed.
RV Comfort Systems
Pbutler97
Midwest
Posted: 11/24/22 01:21am Link  |  Quote  |  Print  |  Notify Moderator
Who catches you for that, the RV code police that patrol campgrounds?
What is a typical RV owner going to have that even has a 20 amp male plug and requires 20 amps. A 25 yr old window air conditioner or a rotary demolition hammer?
* This post was edited 11/24/22 04:50am by Pbutler97 *
JRscooby
Indepmo
Posted: 11/24/22 04:53am Link  |  Quote  |  Print  |  Notify Moderator
Maybe the fire department?
Why do you think the regulations are written? I'm sure I have not followed all in upgrades on my stuff, but if I know about the regulation on wiring, I follow it.
IIRC, my NEC bible is about 20 years old, so maybe some of my upgrades might not be right for a house I rented out, but legal for the 1 I live in.
Pbutler97
Midwest
Posted: 11/24/22 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Why not provide an example of something such as a portable appliance or something else, that an RV owner is going to have or bring to the campground, that has a 20 amp male plug and requires 20 amps.
JRscooby
Indepmo
Posted: 11/24/22 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Well, my camper AC has a 20 AMP plug.
But maybe I should of said FD arson or insurance company investigator. With the drop in price of RVs some people will have trouble making payments. Any time there are lots of people upside down on loans, there starts to be problems with overheated insurance policies.
Pbutler97
Midwest
Posted: 11/24/22 08:02am Link  |  Quote  |  Print  |  Notify Moderator
LOL....Ok......... Happy Thanksgiving
Page of 6
