RV.Net Open Roads Forum: Atwood G6A-7E, what is this part where the plug goes?
 > Atwood G6A-7E, what is this part where the plug goes?
SCADAMAN29325
Clinton, SC
Posted: 11/16/22 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I want to drain the water heater as part of winterizing the RV. I believe that item to the left with the white ring around it is where the plug would go. What is that thing screwed into the plug port. It is the plug port, correct?
Thanks
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19,
It may soon be home (in 4y).
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
2 many 2
Posted: 11/16/22 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
That looks like an aftermarket "Hot Rod", it allows an LP only heater to heat on 120volt electricity as well.
Like This One
SCADAMAN29325
Clinton, SC
Posted: 11/16/22 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting. Maybe that means the previous owner could not get the LP to work.
Hmmm.
SCADAMAN29325
Clinton, SC
Posted: 11/17/22 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Drained the water heater. It's going to get cold tonight.
opnspaces
San Diego Ca
Posted: 11/17/22 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
That's an Atwood water heater. As such it should have a nylon drain plug.
I'll bet the user added the hot rod to supplement the propane.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
SCADAMAN29325
Clinton, SC
Posted: 11/17/22 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'll be checking out the propane sometime real soon. I just want see it fire up to make sure it works.
