time2roll
I would open the manual and see if there is a way to disable the remote start.
675w Solar pictures back up
Sport45
Not far enough from Houston, TX
Pop the hood release and see if that doesn’t disable the remote start.
I believe most factory remote starts are disabled by the hood switch to protect service techs from dumb customers.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
ktmrfs
Portland, Oregon
Sport45 wrote: Pop the hood release and see if that doesn’t disable the remote start.
that and in every car I've seen/had with remote start ALL the doors must be closed, windows rolled up, trunk closed AND the doors locked before a remote start will work. Along with no CEL.
The above is certainly true on my 2015.5 Duramax, along with our Acura, Daughters Ford Escape and DIL mazda 6.
2011 Keystone Outback 295RE
PastorCharlie
NC
Neighbor probably playing with TV remote.
Fisherman
Angus, Ontario, Canada
I would take a quick video of it before heading to the dealer, they may think you're nuts. My trunk had random blinking lights when it was shut off, found it was the ABS module was cracked and winter moisture getting in. The dealer looked at me rather queer, I asked him, you think I'm lying, watch this. He muttered some apologies.
mkirsch
Rochester, NY
Do "all the lights on the dash" normally flash when the remote start is used?
Not on my 2015 Chevy Silverado. Dash doesn't even light up.
Lights flashing on the dash to me is an indication of something not-normal going on.
I would NOT push the truck outside, as that might be the desired result here. If it's hackers driving around the neighborhood looking to see what vehicles start, you might find it missing one morning.
Turtle n Peeps
California
My BMW rolled down every window and opened the sun roof when I was at a gun range the other day. Super weird. I'm glad it wasn't raining and I was away from the car.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
wnjj
Cornelius, Oregon
ktmrfs wrote: Sport45 wrote: Pop the hood release and see if that doesn’t disable the remote start.
Our 2014 Yukon only needs the hood shut, no CEL and the doors locked (even if they’re open).
ktmrfs
Portland, Oregon
rhagfo wrote: Busdriver wrote: Last night was watching tv heard my truck start . Went into my garage truck was running all lights on dashboard was flashing, Has anyone else had this to happen? The key was off
2019 Duramax. 2500 HD 80 thousand miles
Does the truck have remote start? If so did you or DW have a fob in a pocket or purse that may have gotten bumped.
If no remote start I would replace the ignition switch.
at least on my 2015.5 duramax and my 2004 duramax in order to do a remote start with the fob (a) the vehicle must be locked and (b) you must hold the start button long enough for the truck to start. at least 5 seconds, longer when the truck is cold. so, highly unlikely it will be a "pocket start". Same if you use the phone app.
Tvov
CT
Turtle n Peeps wrote: My BMW rolled down every window and opened the sun roof when I was at a gun range the other day. Super weird. I'm glad it wasn't raining and I was away from the car.
A lot of cars actually have that as a "feature", you can remotely roll down (or roll down part way) windows to help cool down the car on hot days.
Many times it is a certain series of button pushing on the remote start.
My sister found that out accidentally on her Honda Passport - even the dealer didn't know at first what was going on with the windows.
Our 2015 Ford Fusion can do it, something about the unlock buttons on the key fob.
2021 F150 2.7
