Janss
Sedona, AZ
If you like more desolate drives, come down through Nevada ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Cedar Breaks Nat'l Monument is in the Dixie Nat'l Forest area. It's like a mini Bryce.
agesilaus described Hwy 89A, which goes from Kanab to Jacob Lake then to Bitter Springs. The more direct route from Kanab to Page/Lake Powell is Hwy 89. And along there is the Toadstools hike (short hike to some cool rock formations) and an interesting dinosaur exhibit at the BLM Big Water Visitors Center.
Top things to do in Page/Lake Powell...Antelope Slot Canyon, smooth water float trip below dam on the Colorado river, walk out to Horseshoe Bend overlook.
If you stay in Flagstaff/Williams, you might want to take a day to drive down through Oak Creek Canyon to Sedona. I think the best way to experience the Grand Canyon is to stay the night in a South Rim campground. More chance to see elk and deer roaming, and sunrise/sunset create beautiful lighting on the canyon walls.
I agree, there is alot to see and do in these parts. You'll have to pick and choose a selection of them to fit into two weeks.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
cptqueeg
Idaho
We stayed at Mather CG on the south rim in late October, 2022. If you stay there or at the RV park nearby you'll have easy access to the bus which you can use to access hikes of varying lengths that follow the contour of the GC. These are relatively flat hikes compared to climbing to the bottom of the GC.
edited 11/20/22 07:29am by cptqueeg *
SteveAE
Bend, Oregon
agesilaus wrote: That is a lot of doing for 2 weeks. There isn't much between Kanab and Lake Powell, especially once you get past Jacob Lake. Which is the entry way to the North Rim of the Canyon.
Agree that two weeks isn't a lot of time. I suggest picking one area and focusing just on that rather than trying to "see it all".
Case in point, I could easily spend a month (even a lot more) between Kanab and Page.
Note that Lake Powell is at historically low levels right now which has it's good and bad points. On the bad, it's sort of ugly with a big bathtub ring and lots of mud between you and the water. On the good, there are canyons that haven't been exposed for decades to explore...all be it, somewhat filled with silt, but they are cleaning out.
If you want a couple good books to help research places to explore, I suggest "Photographing the Southwest, volumes 1 and 2" by Laurent Martres.
covered wagon
toytacoma8 wrote: Have always done the interstate through idaho and salt lake but have always wondered about going through Nevada...
89 will take you an extra day and the end of it will overheat an automatic trans since it's a very long steep grade before you get to 395.
