Skipg
Yuma
I have the standard 4 x 4” rear bumper on my travel trailer. Trying to put in the rhino flex sewer hose with plastic adapter on the end is very difficult does anyone have an alternative way to carry this sewer hose rather than the bumper. Thanks for your input.
Thermoguy
Graham, WA
Camping world has a tube that goes under the trailer. I have one on mine, it is round with a cap, fits 2 sewer hoses connected together. I'm sure you can find it on their website.
goducks10
There
5" Fence post works best.
IAMICHABOD
Sunny So Cal
I keep all my Rhino sewer hoses,The 15 Foot and The 5 Foot extension and all fittings in a Rubbermaid Tote,this keeps them away from everything so it won't contaminate anything and it is stackable.
edited 11/20/22 11:13am by IAMICHABOD *
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
covered wagon
Mine is always connected ready to go. It has a box covering the connection with a door for access. The box has a long tube attached in the rear for the hose to slide and go into which leaves room for fittings in the box.
I open the door, pull out the hose, attach the 90 degree fitting and dump the grey water last to rinse the hose.
When done the hose stays attached and slide the hose back into it's tube and close the watertight door.
I never need to connect nor disconnect the hose this way also eliminating the need to R and R the cap.
time2roll
goducks10 wrote: 5" Fence post works best. +1
675w Solar pictures back up
Second Chance
Wherever...
The RhinoFlex won't fit in one of the made-to-purpose under-frame tubes with the 90 deg. elbow attached, either. Like IAMICHABOD, I keep the main hose and other fittings in a large RubberMaid tub in the basement while on the road. I keep extensions in the two under-frame tubes that came on our rig.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Bobbo
Wherever I park
I have a RhinoFlex and keep it in one of those round holders. However, the sewer connector end won't fit in there. Fortunately, it comes off leaving the 90 degree angle able to fit. I put the end in the propane tank cover on one of the propane tanks.
Bobbo and Lin
1320Fastback
Vista, Ca
I keep our sewer hoses in a solid black tote and all our fresh water supplies in a clear tote. Electrical items in a grey tote.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
routeforty
ohio
I got a 4" piece of pvc about 6' long, put a cap on one end and a screw fitting on the other end and hose clamped it to the top of the rear bumper. Has worked great for me for over 20,000 miles of travelling. Replaced the hose clamps(screw type) once when they got a little rusty. Gary
2018 coachmen leprechaun class c 2008 KZ spree 260FL
