RV.Net Open Roads Forum: Tech Issues: Anode Rod Wear
 > Anode Rod Wear
Mr. C
SW Virginia, USA
Posted: 11/21/22 06:58am Link  |  Quote  |  Print  |  Notify Moderator
What would cause severe wear to the rod at the connection end? Almost no wear on the rest of the rod. I use teflon tape on the threads. Two brand new rods, two years in a row.
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
enblethen
Moses Lake, WA
Posted: 11/21/22 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Are the rods the same manufacturer and which manufacturer?
Something in the water or wrong anode material for that water.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ford truck guy
Pennsylvania
Posted: 11/21/22 07:11am Link  |  Quote  |  Print  |  Notify Moderator
HARD water.. LOTS OF MINERALS in the water your using
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
NorseNW
Battle Ground, WA
Posted: 11/21/22 07:14am Link  |  Quote  |  Print  |  Notify Moderator
My wear like that as well. I've always thought it's the area closest to the other metal source so it wears more there than the "free floating" end. Not sure I'm correct on that but it appears the anode is doing what it is suppose to do.
enblethen
Moses Lake, WA
Posted: 11/21/22 07:29am Link  |  Quote  |  Print  |  Notify Moderator
There are two different materials used for anodes, magnesium and aluminum.
fj12ryder
Platte City, MO
Posted: 11/21/22 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Ours always erodes quickest nearest the threads, which I believe is the reason: closest connection. But just a guess.
Howard and Peggy
"Don't Panic"
MFL
Midwest
Posted: 11/21/22 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Mine too, and same guess.
ktmrfs
Portland, Oregon
Posted: 11/21/22 10:39am Link  |  Quote  |  Print  |  Notify Moderator
yes, basic chemistry and electrolysis. I will corrode from the end closest to where it is attached to the tank and progress down towards the far end.
2011 Keystone Outback 295RE
Mr. C
SW Virginia, USA
Posted: 11/21/22 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
It's this rod. I'll just plan on buying a new one before camping season.
https://www.amazon.com/gp/product/B075MNVPSX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
enblethen
Moses Lake, WA
Posted: 11/21/22 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to switch to an aluminum rod. Keep an eye on it to see if decays more evenly.
magnesium anode link from OP
 > Anode Rod Wear
