MFL
Midwest
Those rods look good, if each had a years use. You can easily get another year of use out of either of those. Looks like 80% or more left, and should be able to use down to 25-50% with still good protection.
Your money, you decide, but changing to aluminum not necessary.
Jerry
BB_TX
McKinney, Texas
I agree that those rods are still good for another year.
I tried changing to an aluminum rod once. After two years it still looked new. Didn’t seem to be doing its job so I switched back to magnesium.
Mr. C
SW Virginia, USA
Thanks for the advice. I'll just reuse the better of the two.
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
RAS43
Littleton,CO
MFL wrote: fj12ryder wrote: Ours always erodes quickest nearest the threads, which I believe is the reason: closest connection. But just a guess.
Mine too, and same guess.
Same with mine. I continue to use it as it will still sacrifice for a time.
ktmrfs
Portland, Oregon
BB_TX wrote: I agree that those rods are still good for another year.
If you have very hard corrosive water that quickly eats magnesium anode rods, then a switch to aluminum is reasonable. If it takes years to do in a magnesium rod, then the magnesium rod is the best choice and provides the best protection.
2011 Keystone Outback 295RE
fj12ryder
Platte City, MO
MFL wrote: Those rods look good, if each had a years use. You can easily get another year of use out of either of those. Looks like 80% or more left, and should be able to use down to 25-50% with still good protection.
Jerry I agree, I switched to magnesium because I was getting a lot of the slimy aluminum compound in the bottom of the tank. Changing to magnesium took care of that issue.
Howard and Peggy
"Don't Panic"
Latner
Indiana
Mr. C wrote: It's this rod. I'll just plan on buying a new one before camping season.
https://www.amazon.com/gp/product/B075MNVPSX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
![[image]](https://live.staticflickr.com/65535/52515782873_a03ee8854a_z.jpg)
lots of life left for those two rods
enblethen
Moses Lake, WA
Here is a good article on anodes
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
GaryUT
Northern UT
That's what the rods from my heater look like after 1 year.
They are not expensive so I just put in a new one in the spring.
I use the Suburban rods, they seem to hold up better.
Suburban 232767 Anode Rod
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
Pbutler97
Midwest
Latner wrote: Mr. C wrote: It's this rod. I'll just plan on buying a new one before camping season.
Yep, if thats from one season of use it looks like they would be good for another 8-10 years, but if folks feel better wasting money every year for a new rod more power to them. Those rods will perform just as well as a new one.
