RV.Net Open Roads Forum: Tech Issues: Anode Rod Wear
 > Anode Rod Wear
MFL
Midwest
Posted: 11/21/22 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Those rods look good, if each had a years use. You can easily get another year of use out of either of those. Looks like 80% or more left, and should be able to use down to 25-50% with still good protection.
Your money, you decide, but changing to aluminum not necessary.
Jerry
BB_TX
McKinney, Texas
Posted: 11/21/22 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I agree that those rods are still good for another year.
I tried changing to an aluminum rod once. After two years it still looked new. Didn’t seem to be doing its job so I switched back to magnesium.
Mr. C
SW Virginia, USA
Posted: 11/21/22 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice. I'll just reuse the better of the two.
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
RAS43
Littleton,CO
Posted: 11/21/22 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
fj12ryder wrote:
Ours always erodes quickest nearest the threads, which I believe is the reason: closest connection. But just a guess.
Mine too, and same guess.
Same with mine. I continue to use it as it will still sacrifice for a time.
ktmrfs
Portland, Oregon
Posted: 11/21/22 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
If you have very hard corrosive water that quickly eats magnesium anode rods, then a switch to aluminum is reasonable. If it takes years to do in a magnesium rod, then the magnesium rod is the best choice and provides the best protection.
2011 Keystone Outback 295RE
fj12ryder
Platte City, MO
Posted: 11/22/22 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
I agree, I switched to magnesium because I was getting a lot of the slimy aluminum compound in the bottom of the tank. Changing to magnesium took care of that issue.
Howard and Peggy
"Don't Panic"
Latner
Indiana
Posted: 11/22/22 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Mr. C wrote:
It's this rod. I'll just plan on buying a new one before camping season.
https://www.amazon.com/gp/product/B075MNVPSX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
lots of life left for those two rods
enblethen
Moses Lake, WA
Posted: 11/22/22 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a good article on anodes
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
GaryUT
Northern UT
Posted: 11/22/22 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
That's what the rods from my heater look like after 1 year.
They are not expensive so I just put in a new one in the spring.
I use the Suburban rods, they seem to hold up better.
Suburban 232767 Anode Rod
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
Pbutler97
Midwest
Posted: 11/23/22 02:12am Link  |  Quote  |  Print  |  Notify Moderator
Yep, if thats from one season of use it looks like they would be good for another 8-10 years, but if folks feel better wasting money every year for a new rod more power to them. Those rods will perform just as well as a new one.
 > Anode Rod Wear
