jornvango
Full-time RVer
We have a portable 100W panel from Renogy that comes with a built-in controller. Two cables go to the battery connect on the RV.
How hard is it to connect a second 100W panel?
I assume we'll need to buy a 100W panel without a built-in controller?
Thanks!
CA Traveler
The Western States
Probably best to buy a second panel with controller and run both sets of wires to the battery.
Otherwise you'll need to access the controller input wires to connect the second panel. Panels should be identical and the controller has to be spec'd for 2 panels and you may void any warranty.
Very common to connect panels in parallel, series or series parallel with 2 wires going to an appropiate controller.
2014 Grand Cherokee Overland
Bob
Ed_Gee
Central Oregon coast
Must also consider the max capabilities of the charge controller on the single panel. It may not be capable of handling more panels.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
pianotuna
Regina, SK, Canada
Not enough information for a good answer. Please send the specifications for the panel and the controller.
Regards, Don
LMHS
NM
When I installed the solar panel on the truck camper, I thought far enough ahead to add a "connection hub". That way I can simply add an extra panel or two and plug it into the hub with out having to rewire the whole mess. But I did know that I would eventually add more panels and batteries. The system is sized to a specific size that I will eventually end up with.
valhalla360
No paticular place.
Are the panels the same brand and specs?
If they are the same wattage but different voltage, that could cause issues as the higher voltage panel may waste energy trying to backfeed into the lower voltage panel.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Tom_M
New Hope, MN
It's best to have the controller close to the batteries. If possible remove the controller from the panel and install it close to the batteries. Do not place the controller in the same compartment as the batteries if they are flooded lead acid.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
jaycocreek
Idaho
I have two 100 watt portable panels that I connect to one of my two portable Renogy solar controllers using a Jackery Y branch..They have the Y branch clones on Amazon...Not sure how your Renogy controller is connected but the two pannels connected, need to go into the input of your controller..The Y branch connects the two panels to make one inputto said controller..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
