RV.Net Open Roads Forum: General RVing Issues: Forever warranty
 > Forever warranty
Mannon89
Alamo,Texas
Posted: 11/23/22 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have experience with a Houston area RV dealer named Demontrond who offers of forever warranty both on used and new RVs?
">aving"> fun traveling down the road with my sweetie (spouse of 35+years)
2112
Posted: 11/23/22 05:12am Link  |  Quote  |  Print  |  Notify Moderator
Here Are Some Reviews. Scroll down and read newest first.
There is a review mentioning the Forever Warranty. Read and understand the contract before you sign.
I haven't heard anything about the Houston locations as I live within a reasonable proximity to the Texas City location. I have heard nothing but bad experiences for them. I drive by there often but never stopped.
2013 KZ Durango 2857
Trainer
Livingston, TX, USA
Posted: 11/23/22 06:36am Link  |  Quote  |  Print  |  Notify Moderator
An Aqua Hot that had annual maintenance as well as the rest of the coach was diagnosed as failed, fresh water coil leaking, was not covered because the "Aqua Hot was not a named component" A $10,000 fix of the interior heating and hot water heating system that was in the coach from new from the factory.
Cptnvideo
Arizona - most of the time
Posted: 11/23/22 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
There is a dealer in a Phoenix suburb that offers the "forever warranty". I recall that to keep the warranty in force that some sort of annual "go over" was required.
We don't do extended warranties - just pay to fix anything that I can't fix. I think it is money saved in the long run.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
Posted: 11/23/22 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Kind of like the "lifetime" warranty another copany offered. Life was 2 years
Pbutler97
Midwest
Posted: 11/24/22 01:09am Link  |  Quote  |  Print  |  Notify Moderator
It's an income generator for the selling dealer's service department designed to keep their income coming forever. You have to take it in to the selling dealer for a yearly inspection that will set you back a couple hundred bucks or more to keep it in effect. Most will find something that needs addressed.
ON AN ANNUAL BASIS, YOU MUST PERFORM THE FOLLOWING MAINTENANCE
* Inspect roof and seal where necessary
* Inspect axles and hub, lube where necessary.
* Inspect furnace – clean blower and combustion chamber, control compartment, (remove any dust, lint, and obstructions) as necessary, test for gas line leaks.
* Inspect hot water heater – flush holding tank, manually operate pressure temperature relief valve, and clean burner tube (as outlined by the manufacturer), as necessary.
None of the required maintenance listed above is covered by the warranty.
Sir, your entire roof needs resealed, $1100.00, your bearings need packed $800.00, your gas lines all need adjusted $500.00, and we have blow lint out of the furnace valvulator, $200.00.
It's a shell game you can't win.
monkey44
Cape Cod, MA and Central Fla
Posted: 11/24/22 05:04am Link  |  Quote  |  Print  |  Notify Moderator
Pbutler97 hit the nail right on the head ^^^^ - and he didn't even need a hammer.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
fj12ryder
Platte City, MO
Posted: 11/24/22 07:30am Link  |  Quote  |  Print  |  Notify Moderator
If something sounds too good to be true...
Howard and Peggy
"Don't Panic"
Posted: 11/24/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
But, but I just got an offer for an extended warranty on my 7 year old truck with 100k miles.
Even said the engine was warrantied…..which is weird since the engine and drivetrain has had a voided warranty (if a claim would have been made) since it was about a week old….
I wonder how they do it? Lol
PS just cracked 100k miles on the ole brodozer this week. Bought it with a little over 60k 2 years ago. It just outlived the warranty period with zero repairs needed. (Except exhaust manifold gaskets which I may have tried to get warranty on but considering how much easier they were to replace without that pesky EGR in the way, I decided it wasn’t worth an argument).
Guess that disproves the “don’t modify or delete or bad things will happen” theory….
Mannon89
Alamo,Texas
Posted: 11/24/22 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thank y’all so much!
 > Forever warranty
