RV.Net Open Roads Forum: Class A Motorhomes: Ford V10
 > Ford V10
haste maker
alabama
Posted: 11/23/22 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone had to replace the throttle body on a V10? And if so what year was your unit & the amount of miles..
Retried Teamster
2007 Allergo
pianotuna
Regina, SK, Canada
Posted: 11/23/22 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
130 thousand miles--no problems with throttle body. One mass flow air sensor. Unit is a 2004.
* This post was edited 11/23/22 09:40pm by pianotuna *
Regards, Don
MountainAir05
New Mexico
Posted: 11/24/22 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
1999 and the only issue was Coil on plugs and a mouse family.
Gjac
Milford, CT
Posted: 11/25/22 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
What makes you believe it needs to be replaced?
haste maker
alabama
Posted: 11/26/22 06:16am Link  |  Quote  |  Print  |  Notify Moderator
It will only idle & the code reads throttle body stuck.
Matt_Colie
Southeast Michigan
Posted: 11/26/22 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Haste,
Look at things carefully, I would suspect the throttle position sensor. It is on the side of the throttle body and they have been know to fail.
Matt - the refugee from Detroit engine labs
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
Gjac
Milford, CT
Posted: 11/26/22 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I would check the senor first as Matt suggested and then spray some throttle body cleaner like CRC and see if that fixes the problem. There is also an IAC valve (air idle control valve) that sometimes sticks that can be cleaned also.
theoldwizard1
SE MI
Posted: 11/26/22 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Nope !
IAC went away when electronic throttle control came in. Also eliminated the cruise control actuator. Eliminating those 2 components, plus better fuel economy and emission controls justified the cost.
theoldwizard1
SE MI
Posted: 11/26/22 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
Haste,
It has been a LONG TIME since I looked at one, but IIRC, on electronic throttle bodies there are 2 sensors (or a dual sensor). One for the microprocessor that runs the throttle motor and one for the ECM.
dodge guy
Bartlett IL
Posted: 11/26/22 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
What year is your coach? Drive by wire started around 06?
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
 > Ford V10
