haste maker
alabama
dodge guy wrote: What year is your coach? Drive by wire started around 06?
2007 year
Retried Teamster
2007 Allergo
Gjac
Milford, CT
haste maker wrote: dodge guy wrote: What year is your coach? Drive by wire started around 06?
2007 year That means your chassis is probably a 2006. Is there an engine code that shows up like a PO505, PO506 or another code that indicates an idle issue? You say it only idles, if you step on the gas will it stall?
haste maker
alabama
Gjac wrote: haste maker wrote: dodge guy wrote: What year is your coach? Drive by wire started around 06?
No it didn't stall when I stepped on the gas..don't know about those codes, I do know it does have the wired throttle body.
haste maker
alabama
Update on my throttle body problem, replaced it & everything runs like or better than before, I seem to have more power now & I know I am getting better gas mileage...thanks for all the reply's.
pianotuna
Regina, SK, Canada
haste maker,
Thanks for letting us know.
Regards, Don
