Samsonsworld
West Texas
So I picked up my new trailer yesterday and it never fails that little things pop up as you spend time in it. This trailer has two doors, the back being the main entrance. The front door opens fine from the inside. I thought everything was in working order. I went to lock up last night and could not get my key in the top lock. It looks pretty boogered up. I cannot open the door from the outside and I can't figure out how to unlock the top from the inside. The deadbolt works fine. I will replace, but in the meantime....is there a way to unlock it without a key?
rdhetrick
Hard to say for sure without specific details, but if it's like most rv door handles/locks, you will need a key for the non-deadbolt lock. Only the deadbolt has the lever inside.
Rob - Solo Full Timer
2017 Winnebago Travato 59G
Former 2006 Mandalay 40E
Mr. C
SW Virginia, USA
If it's like our Cougar, the 2 doors have different keys...
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
Boomerweps
Hills of PA
Mr. C wrote: If it's like our Cougar, the 2 doors have different keys...
Same with my Wolf Pup, different doors, different keys.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
Samsonsworld
West Texas
Yes, I have both keys. All other locks work fine.
Fisherman
Angus, Ontario, Canada
Best lock cleaner you can get is called "Houdini". We used that stuff where padlocks were subjected to dusty and freezing conditions and never had an issue.
newman fulltimer
louisiana
Large screwdriver under the handle give it a pull outwards will pull the little tab out holding it closed
Dtank
Fisherman wrote: Best lock cleaner you can get is called "Houdini". We used that stuff where padlocks were subjected to dusty and freezing conditions and never had an issue.
Learn something new every day!...![cool [emoticon]](http://www.rv.net/sharedcontent/cfb/images/cool.gif)
Google: "Houdini Lock Lube" - - supposedly the locksmith's friend for over 40 years! (reasonably priced)
Samsonsworld
West Texas
After several tries, WD40 finally did the trick. Thanks for the responses. Now to problem #2. My TV sits crooked on the swing mount and its driving me crazy! #3, my shower needs some caulking...easy fix. #4, the front screen door isn't latching...also easy...I think. Its winterized and I'll use the next few months to get it ready for spring.
The good news is, after the maiden voyage, these are the only real annoyances. Nothing major. Everything else is working well.
LouLawrence
Traveling the US fulltime since 2000.
Hope you are headed back to the dealer! It would be complete BS if they did not take care of that any any other little details.
