tourusa
Ft Lauderdale
Hi all
I have a couple of marks look like it’s burnt in to the worktop in the kitchen and bathroom. Any suggestion on how to remove
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
tourusa
Ft Lauderdale
Bumpyroad
Virginia
you might make a small blemish into a large ugly problem. leave it alone.
bumpy
tourusa
Ft Lauderdale
Thanks
CabinetmakerII
Idaho
IF the counter tops are "Solid Surface" (i.e. quartz, or Corian), the blemished area can be wet sanded to eliminate the blemish then polished to restore luster. All of which must be done carefully. Anything other than solid surface, leave it alone.
Good luck!
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2018 Polairs 1000 XP Side by Side
tourusa
Ft Lauderdale
Thanks much
Cummins12V98
on the road
Your first pic shows a textured top likely Corian type??? Looks to be an actual indentation made. I would contact manufacturer. Not much chance of getting that to look good with the textured top. I say defect in the material.
Second pic try using "BioClean" AMAZON type in "Bio Clean: Eco Friendly Hard Water Stain Remover" GREAT product!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Bumpyroad
Virginia
get a professional to look at it and give his/her opinion. as they say, "don't try this at home. "
bumpy
