RV.Net Open Roads Forum: Tech Issues: Securing generator while running
 > Securing generator while running
JBarca
Radnor, Ohio, USA
Posted: 11/27/22 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
A regular cutoff wheel will make short work of a Kryptonite cable/lock DAMHIK
All one can do is slow the thief down--so they will go to some one else.
I use the same Kryptonite cable through the handle and then through a stabilizer jack. I keep it stored in a Rubber Made bucket with a cover, the cable goes on when it is in the bucket. And the genny is in that bucket all the time, other then when it is running or it is cooling down after running, then goes back in the bucket. And, I roll up the shore line cord.
I "never" leave the site when the generator is running. The genny is unlocked when it is running, but I am in camp then. And when both wife and I take the truck and leave the site, the genny goes back in the truck bed with us in the same Rubber Made tub.
I go by the, out of site, out of mind theory. I do not advertise the genny being left out when it is not running.
And, as was said above, any of this is only going to slow down a real thief wanting it, if they know you have it. If they do not know you have it, as they can't see it, then it betters the odds they will not hit you.
I often see many campers leaving their genny out in the open, shut off, not running, for days on end in the same spot. Their bad luck may run out sooner then mine, I hope.
I'm not sure there is a thief proof way to do this.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
valhalla360
No paticular place.
Posted: 11/27/22 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
We use the 10ft bike cable too but it's really about keeping honest people honest.
If we will be away from the camper for any significant period, we generally put it away.
Is there a reason, you are running the air/con when you aren't there?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
mgirardo
Brunswick, GA
Posted: 11/28/22 06:54am Link  |  Quote  |  Print  |  Notify Moderator
A cutoff wheel is overkill on these locks.
Funny story, we were at Disney's Fort Wilderness for Halloween this year. We were tent camping and brought our 5.5' x 10' single axle trailer with most of our gear on it. We parked it in overflow parking after unloading it. I ran a Kryptonite bike lock through one wheel and attached it to the frame of the trailer. I figured at Disney it wasn't necessary, but better safe than sorry.
When it came time to move it to leave, I found I couldn't get the combination to work. I hadn't used the lock in awhile, but I did test it before we left and it worked fine. I always keep a set of 4.5" side cutters in my laptop bag and always have my laptop bag with me. I figured I would have to cut each wire strand individually with those little cutters, but I was wrong. I cut through the steel wire like it was nothing. It was actually more difficult cutting through the rubber/nylon coating than it was to get through the wire.
To the OP: Anyone that can get a set of Catalytic Converters off a car could easily cut through a bike lock or chain. Your best bet would be to keep it out of sight and out of hearing range.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Posted: 11/28/22 07:51am Link  |  Quote  |  Print  |  Notify Moderator
These are all great suggestions or discussion, but what am I missing about the obvious solution….
Use your onboard generator.
Not sure where you camp that backup generator to the generator is necessary. But anywhere I’d even consider that to be possibly needed would be a VERY remote location which in itself is good site security.
But in the absence of removing the temptation from the equation, the proverbial big ole logging chain and big ole pad lock is your best bet.
Like Michael posted above, most bike lock type cables even the expensive ones aren’t that big nor very hard steel and can be picked away at and cut with small hand tools fairly quickly.
Step up to a real chain like 3/8 Gr 80 or heavier or heavy rigging cable choker if you want to eliminate the tweakers who aren’t even smart enough to have stolen a cordless grinder yet…
What I can tell you is a shiny red Honda 3k genny is right up there with F250s and Toyota Camrys on the tweakers Christmas lists. Unlike some of the rvnet folks who sit around here and say how the cheap china gennys are so great and just as good as Hondas, the “pros”, those who are powering homeless encampments and/or hocking them at pawn shops 100% realize the additional value of obtaining a quality generator…lol.
pbitschura
SE MN
Posted: 11/28/22 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I'd bet you have spent some time in Slab City. Ha Ha.
2020 Braxton Creek 24fb travel trailer
Posted: 11/28/22 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Ha, no! I had to look it up actually!
Never even driven past the AZ state line on I-10 or I-40.
pbitschura
SE MN
Posted: 11/28/22 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Hope this helps
I guess since I live in a place that doesn't require infinite vigilance, protecting against crimes of opportunity are all I'm going to prep for. Thanks.
John
2oldman
NM
Posted: 12/02/22 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Vulcan chain
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/02/22 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Lay an empty .357 magnum ammo box on top?
deltabravo
Spokane, WA
Posted: 12/07/22 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I would never leave my portable generator running if I left the RV to go do other activities.
