tourusa
Ft Lauderdale
Hi all
I have a 2020 fifth wheel and noticed some rust marks or looks like rust could be desert dust here in AZ see picture and let me know your thoughts
![[image]](https://i.imgur.com/sYUgZM6l.jpg)
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
dedmiston
Coast to Coast
Administrator
It's hard to be certain from those photos, but it looks like your gutter might be leaking and causing a rust stain. Can you hit it with a garden hose and see if it drips or drains in that spot?
Toys:
- 18 Can Am Maverick x3
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
tourusa
Ft Lauderdale
Thanks much I will be cleaning it and will try that out
Roger10378
Goodrich, MI.
It looks like a joint in the trim just to the left of the stains. My guess is that water is getting in and rusting the screws.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
tourusa
Ft Lauderdale
Thanks I’ll look and replace with stainless with some sealant on the head
MFL
Midwest
Roger10378 wrote: It looks like a joint in the trim just to the left of the stains. My guess is that water is getting in and rusting the screws.
^While we are just guessing, that is a good guess! Those screws that hold trim, gutters, or many attachments rust easily. unless sealed well.
Jerry
Pbutler97
Midwest
It also looks like there are 3 places in the insert trim of the gutter where its spline is pulling out of the channel.
bobsallyh
Livingston, TX.
tourusa, how long have you been in AZ? After being here 20 years, looks like AZ. dust that has settled on roof, etc. When it gets damp, it tends to do what I see in the pictures. Rain can cause it but if enough rain it generally just runs off or collects in numerous places. Reminds me of weak coffee or weak hot chocolate. Have you been up on the roof to check out accumulation of dust?
tourusa
Ft Lauderdale
Sounds and looks that’s what it is has a wash am. It’s been in AZ all it’s life I’ll keep you posted
mhardin
Texas!
The only way of knowing is to get up there and do a close inspection. Anything else is just speculation.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
