RV.Net Open Roads Forum: General RVing Issues: Gasket/molding issue
 > Gasket/molding issue
wanderingaimlessly
Kerr Reservoir
Posted: 11/28/22 07:16am Link  |  Quote  |  Print  |  Notify Moderator
On my 2010 Winnebago, there is rubber molding that covers the joint between the upper and lower body panels. The rubber strip on the passenger side from the entry door to the back (about 12 feet) has now come out three or four times. I can push it right back in with just my thumb, but within a few days it starts coming back out. I dont want to replace it with new rubber because it is painted to match the body panel.
My first thought is to put a drop of adhesive on the top joining surface every foot of so to stop it from dropping to the bottom of the track (there is maybe a 32nd of an inch of free play) which is how it is coming free.
Or is there some rubber conditioner I should use to expand what I am guessing is shrinking rubber from it drying out over time?
* This post was edited 11/28/22 07:25am by wanderingaimlessly *
ScottG
Bothell Wa.
Posted: 11/28/22 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Had an RV doing that many years ago. I just put a few small dots of silicone behind it and it never came out again. It would easily come apart if you wanted it to though.
Be gentle or the paint will come off the strip.
opnspaces
San Diego Ca
Posted: 11/28/22 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I would also put some adhesive every few feet to hold the molding in place. You could use some blue painters tape to temporarily hold the molding until the adhesive dries. Once dried carefully hold the molding in place while you peel off the tape.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Bobbo
Wherever I park
Posted: 11/28/22 10:12am Link  |  Quote  |  Print  |  Notify Moderator
When that happened to mine, I put a generous amount of E6000 behind the strip and held it in place with tape overnight.
Bobbo and Lin
wanderingaimlessly
Kerr Reservoir
Posted: 11/28/22 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all, I just used some clear silicon I had aboard, a dot every foot or so and scotch tape for overnight.
JRscooby
Indepmo
Posted: 11/28/22 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
I once bought a trailer with the light holes cut oversized. Drop a load of shot rock in it, all the lights and gaskets would be hanging by wires. Clear silicon around each one, lights stayed in for 3 years at least, sold trailer.
You should be good.
harryjr
SE CT
Posted: 12/05/22 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
You can contact steelerubber.com/camper-rv.
They are willing to send you samples to test fit replacements for size. Very well made product and much better than OEM.
Harry Jr.
Southeastern CT
larry cad
ohio
Posted: 12/05/22 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the clicky. Leave off the . at the end
Our Travel Blog
donkeydew
OR
Posted: 12/05/22 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
google trim molding insert
