RV.Net Open Roads Forum: Tow Vehicles: Tesla delivers there first semi
Search only in Tow Vehicles
 > Tesla delivers there first semi
Page of 11
Dadoffourgirls
China, MI USA
Posted: 12/05/22 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Turtle n Peeps wrote:
Reisender wrote:
The route was between Freemont and San Diego via the grapevine as per the published data. It used 94 percent of the battery to go 500 miles.
Truck was loaded to just under 82000 pounds as per presentation.
Was this independently checked by a 3rd party? How big was the battery? Was the battery size independently checked by a 3rd party?
Were any of the weights independently checked by a 3rd party? There are several commercial truck scales that are mandatory to go over on this route. Do you know if they showed the actual weight ticket with the time and date printed on the ticket? If not, why not?
Was ANYTHING checked by a 3rd independent party? If not, non of this means anything.
I agree that I would like to see an independent assessment. Let's give one to TFL.
I would like to see this trip in reverse. Let's make sure it can go 500 miles in two directions.
Let's see this vehicle in operation in Ohio, Indiana, or anyplace that is currently near freezing.
And I hope the taxpayers appreciate this. I read that they are paying $15.4 Million for Pepsi to have this.
And I hope you approve of the $40,000 per every semi coming from the Federal Government. That would be like giving 4 people $10k towards their student loans.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
Dadoffourgirls
China, MI USA
Posted: 12/05/22 05:13am Link  |  Quote  |  Print  |  Notify Moderator
And when will Pepsi get the second semi?
Reisender
NA
Posted: 12/05/22 07:20am Link  |  Quote  |  Print  |  Notify Moderator
They took delivery of the first two already.
Posted: 12/05/22 11:14am Link  |  Quote  |  Print  |  Notify Moderator
While I agree w you wholeheartedly, at least it’s not the worst or most wasteful thing our govt subsidizes! Doesn’t even make the top 10.
stsmark
Northern CA
Posted: 12/05/22 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Here’s an info sheet from FritoLay on the sustainability project at Modesto plant from 2019,
https://fritolay.majestic.dev/sites/fritolay.com/files/2020-08/zanzeff_layout4-01.14_r2%20%281%29%20-%20FINAL.pdf
* This post was edited 12/05/22 04:30pm by stsmark *
Learjet
Louisiana
Posted: 12/05/22 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
hang on doubters...it's only going to get better [emoticon]
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
Turtle n Peeps
California
Posted: 12/05/22 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
Really good question. Here is one answer to your question and it's not good. And this is in what I call moderate cold. 30 degrees F is not really cold even in Kalifornia. Many parts of the US get into negative numbers. Now that's cold!
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
schlep1967
Harrisburg, PA
Posted: 12/06/22 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
SO they left an elevation of 5,000 feet and drove basically downhill for 500 miles to an elevation of 5oo feet in a truck that regenerates it's batteries when going downhill.
Can it make the same loaded run in the other direction?
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
Reisender
NA
Posted: 12/06/22 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmm. You may be interpreting that graph wrong. They went from Fremont to San Diego via the grape vine. So start at roughly sea level, over the grape vine and back to roughly sea level. Start in the bottom left hand corner to see the altitude and follow the changes. The grape vine is pretty obvious but there are some other grades as well.
This kind of graph presentation is common to all Tesla software displays.
* This post was edited 12/06/22 01:51pm by Reisender *
schlep1967
Harrisburg, PA
Posted: 12/07/22 05:18am Link  |  Quote  |  Print  |  Notify Moderator
You are correct. I was reading the graph incorrectly. Ignore my last.
Page of 11
