fj12ryder
Platte City, MO
I read a review of that video, and the main complaint was the amount of time the speedometer was blocked from view. The person felt that much of the time it seemed to be done deliberately. I dunno, I've not watched it.
Howard and Peggy
"Don't Panic"
Reisender
NA
fj12ryder wrote: I read a review of that video, and the main complaint was the amount of time the speedometer was blocked from view. The person felt that much of the time it seemed to be done deliberately. I dunno, I've not watched it.
I haven’t seen it yet. Liability reasons maybe?
Pepsi now has 5 of them. They took delivery of all 5 on the first but apparently only 2 were branded. They apparently have the other three now. They are supposed to have roughly 15 by the new year but Pepsi hasn’t confirmed when they get the rest.
Turtle n Peeps
California
Reisender wrote: stsmark wrote: While it is capable of going up the Grapevine at 60, is there video of that? It would have been speeding as the towing limit in CA is 55. I’d really like to see the consumption doing it as if I understand correctly all 3 motors would be working in that situation. I’m sure it’s well under a mile per KWh then.
Said it before, Pepsi is beta test. I’m sure it will do great for them as the use pattern is set for success.
There is a time compressed video on you tube. You can kinda see the display and topography so I guess that’s a yes. I won’t bother to look at it but if you have the time you might be able to see all the details.
Here is the video that explains everything about the Tesla Semi. It even talks about the thermal nuclear glass that is in this truck and many, many other details about this Semi.
Pretty cool!!! I never heard about the thermal nuclear glass? I learn something every day!
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
stsmark
Northern CA
Ok couldn’t sleep, watched both videos. I’ve driven I-5 to SoCal a lot of times. If you look at the graph Tesla provides for the trip you can see the point where it starts the climb up the Grapevine. The area at the base is named Wheeler Ridge it’s at the south end of the flat Central Valley a mile or so further starts the real climb. The top of the climb is Tejon pass at 4136 ft as they say. Beyond it a mile or so is the town of Gorman. It is 18 miles from Wheeler Ridge to Gorman after Gorman the road flattens for a bit before you start down. On the graph it’s at 50% charge when the elevation starts rising per Tesla. It at 32 % as it crests the pass so it used 18% to go 18 miles uphill. I think it has a 1000 kw pack it has to be at least 950 kw. So 18% of the pack is 180 kw or 10 kw a mile. No magic there.
It’s interesting I ran same experiment of miles and percentage used on the leg from Tesla factory to Kettleman City and it used about 1.8 kw a mile. So under ideal weather and traffic (from the video) on level ground at 55 it seems like will do what they said.
Now let’s see what Giga Factory Reno to Salt Lake City which is 502 miles per Apple Maps looks like. Iirc I-80 is 70 or 75 mph all the way. Your probably looking at Wells or Wendover max at that speed.
Thermoguy
Graham, WA
I learned yesterday that Tesla is getting a lot of press for Pepsi receiving these Tesla Semi's. However, they already have a couple dozen EV Trucks from Paccar, which is Kenworth and Peterbilt. So, this is not their first or will it be the last EV trucks they purchase and put to use.
In addition, Paccar mentioned they are working on hydrogen fueled and hydrogen hybrid trucks and engines. Much like BMW, Toyota and others. So, the big question, what alternative fuel vehicles will become main stream in the long run.
ford truck guy
Pennsylvania
Well,
The Paccar has a Peterbilt here are its technical specs... note the the daily mileage
Battery Recharge Time – 3 Hours
• Estimated Daily Range – 150 Miles
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Groover
Pulaski, TN
Turtle n Peeps wrote: Reisender wrote: stsmark wrote: While it is capable of going up the Grapevine at 60, is there video of that? It would have been speeding as the towing limit in CA is 55. I’d really like to see the consumption doing it as if I understand correctly all 3 motors would be working in that situation. I’m sure it’s well under a mile per KWh then.
The narrator lost me in the first 30 seconds. First, how did he divine how much weight is inside the enclosed trailer? Second, how did he calculate that there is only 5 tons of material on the Tesla's trailer? Those look like standard 10ft Jersey barricades to me and there appears to be 11 or 12 of them on the trailer. A Google search turned up the bit of information "The most common concrete jersey barricade size used is: 10 ft Long x 24 in Wide x 32 in High and weigh approximately 4,000 lbs." That is two tons each. 11 dividers X 2 tons/divider = 22 tons.
Once I realized that narrator was blowing smoke I just shut it down.
Turtle n Peeps
California
Groover wrote: The narrator lost me in the first 30 seconds. First, how did he divine how much weight is inside the enclosed trailer? Second, how did he calculate that there is only 5 tons of material on the Tesla's trailer? Those look like standard 10ft Jersey barricades to me and there appears to be 11 or 12 of them on the trailer. A Google search turned up the bit of information "The most common concrete jersey barricade size used is: 10 ft Long x 24 in Wide x 32 in High and weigh approximately 4,000 lbs." That is two tons each. 11 dividers X 2 tons/divider = 22 tons.
Well that's too bad. If you would have continued on to about the 9 minute mark you would have found out that a conventual diesel semi can haul twice the amount of barriers that the Tesla did. Over twice in fact.
And if you would have went to the 25 minute mark you would have learned about the nuclear glass in this semi. Now that's somethin a truck driver worries about. I remember when I drove a truck for a few years long ago it was one of my major concerns.
BTW why the mystery about gross and net weight? Why not show the weight ticket? Seems to me it would be a great selling point......unless the figures are out to lunch. Then I would want to keep it more secret than KFC's 11 herbs and spices!
Speaking of numbers. You might want to watch this video. Lots of numbers in this video. He breaks it down pretty good and comes up with about the same numbers and facts I did years ago.
time2roll
https://www.reuters.com/business/autos-t........on/pepsico-roll-out-100-tesla-semis-2023
Nice but I am still drinking CocaCola...
675w Solar pictures back up
Huntindog
Phoenix AZ
I just did the math. Pepsi is getting 194,000 off each one in subsidies. Pepsi is going green alright, the color of money green!
edited 12/17/22 07:22am by Huntindog *
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
