RV.Net Open Roads Forum: Tow Vehicles: Insert pins
Search only in Tow Vehicles
 > Insert pins
Horsedoc
Dixie --- N. Georgia
Posted: 12/05/22 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Loaned my Ram 1500 to a relative the other day and upon return the insert from the hitch was in the bed but the pin was missing. I had a pin with a hole that a clip key slid into. I was pretty sure this would not come out as it was hard to pull w/o pliers. Not a big deal to replace but I needed to use the truck. Local hardware and the only thing he had was a Reese pin with a groove around the end that the hairpin style clip fits around. Is on style safer than the other? Just seems like the clip through the pin would be less likely to come out. Am I worried for no reason?
BB_TX
McKinney, Texas
Posted: 12/05/22 08:01am Link  |  Quote  |  Print  |  Notify Moderator
All the ones I have ever used had the groove around the pin and never had one come loose or come off after many miles of towing various trailers.
mkirsch
Rochester, NY
Posted: 12/05/22 08:13am Link  |  Quote  |  Print  |  Notify Moderator
The pin on my Dad's truck has the groove, and it's one of the hardest pins to get the clip on and off of. I'd say it's as secure as any other.
PA12DRVR
Back in God's Country
Posted: 12/05/22 09:41am Link  |  Quote  |  Print  |  Notify Moderator
I tend to lose pins and clips at a 1 x per year basis since I set it down ("I'll remember that location") and then walk away or drop it in the snow or something similar. My "fleet" (4 vehicles, 3 UTV/ATV, all with receiver hitches of one size or the other) was equipped with the Reese pins with grove. As I lose them, I'm replacing with the style the OP mentioned in his post.
I've never had either style clip or pin come out without an external (i.e. me) influence.
CRL
My RV is a 1946 PA-12
Back in the GWN
p220sigman
Tallahassee, FL, USA
Posted: 12/05/22 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I've used both and never had either one lose the clip. The grooved one was easier for me because I didn't have worry about the orientation of the clip hole when putting the pin in.
Posted: 12/05/22 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Not an issue OP.
Cummins12V98
on the road
Posted: 12/05/22 11:11am Link  |  Quote  |  Print  |  Notify Moderator
You need a straight pin without the curved end. Problem is the curved end will cause an egg shaped hole in the receiver. This has been discussed thoroughly on the TDR.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
valhalla360
No paticular place.
Posted: 12/06/22 12:28am Link  |  Quote  |  Print  |  Notify Moderator
Not that I would ever recommend going without the retaining clip, reality is the pin is very unlikely to come out even without the retaining clip. The clip should never be under any significant stress.
I've had both and never had one come off. If it was an issue, you could expect there to have been lawsuits and an unsuitable design would have long ago left the market.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bucky
Raleigh metro
Posted: 12/06/22 05:35am Link  |  Quote  |  Print  |  Notify Moderator
They make them with a built in retainer as in the link
Can't lose the pin clicky
Puma 30RKSS
mkirsch
Rochester, NY
Posted: 12/06/22 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Those don't work well in this climate. A little salt and rain, and they seize up.
 > Insert pins
