RV.Net Open Roads Forum: Tech Issues: Heated Floors
 > Heated Floors
Posted: 12/17/22 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Aside from the obvious and probably some unexpected costs and challenges of installation, you’re burning a ton of electricity. Let’s not pretend a hydronic system is even remotely feasible.
Best option for heated floors is a his n hers pair of heated socks or slippers….
theoldwizard1
SE MI
Posted: 12/18/22 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
Heated floors,(liquid or 120 volt grids), ARE NOT designed to heat an RV. They are designed to keep the cold floor from bothering you. The ONLY heated floors I have seen are under tile floors. Doug
True, but if you have power (not generator or battery) a heated floor mat and a couple of 1500W heaters would definitely keep a 20+' RV warm down to freezing !
theoldwizard1
SE MI
Posted: 12/18/22 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Heated mattress pads and a extra blanket worked better than an electric blanket.
If you are really "roughing it" and sleeping with no heat, a knit hat makes a huge difference (old Boy Scout lesson learned)!
ssthrd
Vancouver Island
Posted: 12/18/22 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
My grandmother used to say that if your feet are cold, put on a hat........
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
pianotuna
Regina, SK, Canada
Posted: 12/19/22 06:42am Link  |  Quote  |  Print  |  Notify Moderator
My peak load was 7100 watts and the average was 4300 watts per hour when temperatures were in the area of -37 c (-34 f). That works out to about 103 kwh per 24 hour day.
To do so I had two auxiliary shore power cords (15 and 20 amp). I used an autoformer on the OEM 30 amp to support the voltage.
Regards, Don
 > Heated Floors
