bobndot
mountaintraveler,
As long as you thought it thru and are comfortable. Knowing all the variables is where you want to be.
Just something to be aware of for people like us who go into the woods. When you are looking at rvs, pay attention to the dump valve location. On newer models, the dump plumbing is usually tucked up inside an exterior compartment. On older models, it's exposed and easier to hit it something. Ground clearance of that plumbing setup is less. If your rear wheels dip into a low spot on the trail, that plumbing may touch the ground.
RE: $3k. it was FYI. If you bought new towing equipment to outfit your car to tow it. I wasn't sure you were renting a dolly or not.
kwplot34
home
With all the issues that have been mentioned trying to get the Toyota camry/corolla into a spot, backing into rocks and trees. A class C no matter what length is not something you should get. And it sounds like from your post that you have some vision issues.
Driving a class C is not like driving the pickup you rented.
Just being honest with you.
valhalla360
No paticular place.
mountaintraveler wrote: klutchdust wrote: When you say you want to go to the same places you went to in your car that raised my eyebrows a bit. My 30ft. had a fair overhang in the back and it dragged pretty easy going into certain roads and areas. If you have no experience driving a larger vehicle it can get interesting real quick. I have found no issues with parking, their limits are so one vehicle doesn't take two spots, like some do at truck stops which annoys the truckers.
I suggest renting what size you are interested in and try it out for a weekend or so.
I see. That's important for me to know about 30ft overhand,
some 26' also have noticeably more overhang.
Toyota Camry is not a 4wd, to put it mildly, and has low clearance -
yet I was able to go miles and miles on all kinds of very uneven bumpy gravel and dirt roads, without damaging the bottom (one time I did reseal of oil pan, though, cost me a fortune at a dealership)
I'm not in a position to do RV renting now.
I'm buying a motorhome next week and heading back out West on it after inspections and fixing up anything that needs to be.
What you say seems to point out that it'd be safer to get a 24' one.
I have bad eyes.
Also, my eyeglasses' plastic frames limit my field of vision. No one to help parking. I get very tired on long drives, become no good at parking from fatique. Had adventures with my Camry's bumper meeting pine trees and boulders, definitely and a 20' campsite can be hard to back even a Camry into when you're tired. Can't imagine what happens with long vehicle. Shorter RV is definitely safer bet in terms of not hitting things and not scraping.
Generally speaking a Camery is a much better off road vehicle than a 24/26 ft class C. The short wheel base and minimal overhangs will avoid most issues that a Class C will experience.
Also, if you do abuse it, the Camery will take it far better. The house part of an RV is not very tough and durable. Even just bouncing down a rough road without bottoming out can tear one apart in conditions the Camery wouldn't have a problem with. Back into a tree or boulder and it can be major damage that would only be a dent on a Camery.
In addition to finding things under/inside furniture, be careful of going to extremes removing furniture as the furniture often acts to add strength & stiffness to the outside walls. Removing a cabinet by itself is unlikely to have much impact but if you gut the thing, it may become a floppy unstable mess.
Honestly, the difference between 24 & 26 ft is unlikely to be noticeable in real world use and the least of your worries. Just get the one that meets your budget/layout preferences.
Also, concerning is that you will be too tired after a long drive to back in safely. If true, you are probably a danger on the road long before you reach the campground. Much better to plan shorter driving days. When you are tired is when you make stupid mistakes.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
ppine
Northern Nevada
Buy the 26 footer and don't look back.
pianotuna
Regina, SK, Canada
Hi,
The over hang in of itself is not much of a problem.
Tail Swing IS a bigee.
I went from 27' to 28'5". I had four tail swing accidents in 2 years with the 28. I had none in a 9 year period on the 27'
Regards, Don
Bordercollie
Garden Grove, CA, USA
Our 2004 Fleetwood model 26Q measures 27 feet long bumper to bumper.
pnichols
The Other California
Here's us camped with our Ford E450 based 24 ft. Class C out on the far side of beyond in Death Valley ... notice that the coach body starts out sweeping immediately upwards from the rear wheels back so as to minimize tail dragging when starting on side road or parking lot upgrades:
![[image]](https://i.imgur.com/q4ri0x9l.jpg)
Here's us driving out of a woods campsite alongside a river that has overflowed it's banks ... it probably takes a Ford or Chevy chassis under a Class C to provide this kind of stock ground clearance (we now have larger-than-stock-diameter tires on it for even more ground clearance):
last
edited 01/21/23 08:22pm by pnichols *
View edit history
2005 E450 Itasca 24V Class C
