Lantley
Ellicott City, Maryland
My RV's have been plugged in 24/7/365 since 2005 with no ill effects.
The only time it is unplugged is when it's going down the road!
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
time2roll
Skipg wrote: What’s your thoughts about leaving a RV plugged in to shore power when not in use. I read it not good for the house batteries.thanks for your input. Will not hurt the battery in winter.
Otherwise post the battery voltage for best answers.
675w Solar pictures back up
2112
I have the infamous WFCO converter that is stuck on 13.6V. Too high for long term maintenance charge. It's a battery boiler.
I have a timer that tops off the battery for 1 hour every 3 days.
2013 KZ Durango 2857
cummins2014
Utah
Lantley wrote: My RV's have been plugged in 24/7/365 since 2005 with no ill effects.
Same here !!!!
joebedford
Seriously thinking about heading home soon.
I leave my TH plugged in all the time. It has a 100 amp WFCO converter with no battery ill effects. YMMV.
theoldwizard1
SE MI
IMHO, if you are storing for more than a month, disconnect the battery.
For best life, lithium batteries should not be subject to below freezing temperatures.
Bobbo
Wherever I park
If you have a true multistage charger, then it will take care of your batteries. That leaves out Parallax, Magnetek, and WFCO. Since getting my Progressive Dynamics, I have left the RV plugged in and charging 24/7/365. That is about 13 years now.
Bobbo and Lin
pianotuna
Regina, SK, Canada
13 years on one set of batteries?
Regards, Don
Bobbo
Wherever I park
pianotuna wrote: 13 years on one set of batteries?
No. Batteries do age out. Two sets of batteries. But, they were not prematurely killed by the charger staying on 24/7/365. I got 8 or 9 years out of the first set. Still on the second set.
K3WE
Missouri
20 years ago, I cooked a set of batteries, when plugged in to the house. Thus, the rule is “factually real”
New camper with one-year plug in- batteries OK.
This is consistent with old chargers often being bad for extended use and new ones generally being ok.
Double check the model if you have concerns.
