RV.Net Open Roads Forum: Fifth-Wheels: Re-level 5er with lippert hydraulics
 > Re-level 5er with lippert hydraulics
Carls wood works
Brookings
Posted: 12/20/22 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Our trailer needs to be re-leveled after sitting in our spot for 6 months. I have found a wealth of info on the system but nothing about re-leveling. Do the slides need to be in? Do I need to be in manual mode? Can I just push Auto Level? Need help
mooky stinks
Cicero,NY
Posted: 12/20/22 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Put your slides in and hit auto level.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
wvcampers
United States
Posted: 12/20/22 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have done a relevel a couple of times. I don't put the slides in. Just push the level button. Keep in mind that the trailer will not return to hitch height when you hit the hitch button. it will go to where it was before you did the last level. you will need to manually get the trailer to the correct height to with up.
2017 F350 6.7 CC Lariat DRW
2018 Cardinal Luxury Edition 3250 RLX
dedmiston
Coast to Coast
Administrator
Posted: 12/21/22 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Hi Carl - Welcome to the forum.
Interesting question for your first post..
I never deploy my slides until I'm level. Running them out when the fiver isn't level puts stress on them and can make them bind up.
But you're already kind of out of level and your slides are already out. You're probably better off running the auto-level as you are instead of running the slides back in. Hopefully you're not that far out of level.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 12/21/22 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I think I would just make use of the Manual Level and just touch of what is needed. Would be quicker and easier.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Learjet
Louisiana
Posted: 12/21/22 07:33am Link  |  Quote  |  Print  |  Notify Moderator
6 months....probably a good time to exercise the slides and slide motors.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
fj12ryder
Platte City, MO
Posted: 12/21/22 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Tough to get much easier than to hit the AutoLevel button, one and done.
Howard and Peggy
"Don't Panic"
way2roll
Wilmington NC
Posted: 12/21/22 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Depends. The auto levelers on some RV's I've had operated like a Rube Goldberg machine and did some pretty funky stuff and often more than it really needed to. If wasn't already leveled to begin with not much of an issue, but since it was already leveled once doing it again with the slides out could extend jacks further than they need to be or some frame flexing etc. With the slides out that could be a problem. Manually bumping it a bit an inch or 2 on one side or on end is less dramatic than going through the whole auto level cycle.
* This post was edited 12/22/22 08:44am by way2roll *
2023 FR Sunseeker 2400B MBS
CoMoCo
Welland, ON, Canada
Posted: 12/22/22 04:34am Link  |  Quote  |  Print  |  Notify Moderator
Why has it become out of level? Have the jacks sunk further into the ground?
I would pull the slides in and retract the jacks and ensure the ground below the jacks is stable. Then put boards (or plastic pads) under the jacks to make sure the trailer is as stable as possible.
'15 GMC Denali 3500 DRW D/A; '22 Cedar Creek 345IK
Cummins12V98
on the road
Posted: 12/22/22 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Correct!!! I have small levels that are stick on placed at exactly "LEVEL" so I simply use manual mode to adjust to the small levels.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
