fj12ryder
Platte City, MO
Cummins12V98 wrote: "Well, maybe yours does that, but my front levelers are completely independent of the center/rear levelers when in Manual"
I did NOT say the fronts were part of the rears but they DO adjust when the side is raised or lowered if they did not the frame would be in a twisted condition. Front legs equalize to the side by side created by the rears. We agree now?
The sides adjust to each other also so one is not supporting more than the other. Nope, we totally disagree. I have worked with mine when I was changing tires, and I can positively tell you that my sides will move independently of one another. I can raise one side, but not the other. I can raise one side, and not the front.
And what you stated: "I did NOT say the fronts were part of the rears but they DO adjust when the side is raised or lowered if they did not the frame would be in a twisted condition." is incorrect. The fronts, on my trailer, do not adjust when the side is raised or lowered, which leads to my statement that Manual adjustments can lead to a frame that is not equally supported by all levelers.
This is the way mine works, yours must work differently. But please don't presume to tell me how mine works.
Howard and Peggy
"Don't Panic"
stickdog
Somewhere, USA
fj12ryder wrote: stickdog wrote: I can tell when our trailer is out of level just by walking back to front. I'll just go to the panel and turn the system on and it will say "out of level". I hit auto level it does its thing and all is well and level. I try to not overthink things gets you into more trouble than out. Ah, you can settle a disagreement: does the Autolevel go through its total cycle, or does it just move enough to relevel?
TIA
It doesn't go through the whole setup like dropping the front end I just push Auto level and pump makes pump noise trailer moves, pump stops diodes say checking for level, then "Success".
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
fj12ryder
Platte City, MO
stickdog wrote: fj12ryder wrote: stickdog wrote: I can tell when our trailer is out of level just by walking back to front. I'll just go to the panel and turn the system on and it will say "out of level". I hit auto level it does its thing and all is well and level. I try to not overthink things gets you into more trouble than out. Ah, you can settle a disagreement: does the Autolevel go through its total cycle, or does it just move enough to relevel?
TIA
It doesn't go through the whole setup like dropping the front end I just push Auto level and pump makes pump noise trailer moves, pump stops diodes say checking for level, then "Success". Well, I guess we'll go with what people say who actually do it. Guess that "If you hit AUTO the nose will dive and go thru the whole auto level process." statement posited as fact is WRONG. Wonder what else was incorrect?
Cptnvideo
Arizona - most of the time
fj12ryder, Cummins12V98 is correct. Once all 6 jacks have a load, they work in unison and never bind. Naturally, when you raise/lower the rear, the front jacks do NOT move. Same when you raise/lower the front - the rear jacks do NOT move. And the same for raising/lowering the left or right sides. Think about what you are saying.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
fj12ryder
Platte City, MO
I see what you're saying, and I believe you and Cummins12V98 could be correct. I was laboring under the misapprehension that the levelers will stay where they are set. You're saying that they will level themselves like they do when the pump is running. More weight on the left will cause the left to lower and the right to raise as the pressure equalizes. That sounds reasonable. I was simply too blind to see it.
But I can see raising the left and right could cause the front levelers to become unweighted evenly, hence the trailer would be supported mainly on the center/rear levelers on both sides. But you would almost have to do that deliberately.
I apologize humbly to Cummins12V98. In this instance he was right and I was dead wrong. Sometimes it really does help to consult the brain before engaging the mouth. I hate being wrong, but you'd think I'd get used to it after all these years. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Again, I'm very sorry Cummins12V98. Beers are on me.
fj12ryder
Platte City, MO
I still think that hitting AutoLevel is the way to go.
Cptnvideo
Well said, Ryder.
I once had an occasion when the auto level lowered the landing gear all the way (due to slope) and kept trying to lower. I canceled auto and went to manual. Raising the rear caused all 4 jacks to contact ground then lift the rear. Then I could raise the front a little creating front to rear level. Then the left side needed raised a little for side to side level. Raising the left side caused all 3 left side jacks to extend in unison.
I've only had the 6 jack system since March and that was my first and only time manually leveling.
Cummins12V98
on the road
fj12ryder wrote: I see what you're saying, and I believe you and Cummins12V98 could be correct. I was laboring under the misapprehension that the levelers will stay where they are set. You're saying that they will level themselves like they do when the pump is running. More weight on the left will cause the left to lower and the right to raise as the pressure equalizes. That sounds reasonable. I was simply too blind to see it.
You are a real MAN I say!!! Thank you for your kind words.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
fj12ryder wrote: I still think that hitting AutoLevel is the way to go. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
i will admit that I have never hit auto level to just move it a tiny bit so I can't say mine will dip. I can only say it sure drops when I have unhooked from truck and hit auto.
fj12ryder
Platte City, MO
I have some of the Andersen red round blocks that came with the trailer. I used them several times and then I was flummoxed when one time they wouldn't work. The nose couldn't go down low enough to start the AutoLevel I guess. I took them off, used a couple three of the yellow square blocks and all was well. After I did some more research I started to recognize when I could use the Andersen blocks and when they put the nose too high. Live and learn.
And I'm also unsure about the incremental AutoLevel, but Stickdog says it just relevels and doesn't start from square one. That sounds like a win to me.
