Likes to tow
Huntington WV
I have a 2021 Ford F250 with the 7.3 gas engine and the 10 speed transmission. It was bought new and has 20k on the odometer. Supposedly there is no scheduled maintenance on the transmission! I've always changed transmission fluid in all my previous trucks at 30k miles but the dealer says this will not need it. There is no dipstick!
Also......... Is the 10 speed in my F250 7.3 gas the same as the 10 speed used in the F350 thru F550 with the 6.7 diesel engine????
way2roll
Wilmington NC
It's the same transmission and you are correct there is no scheduled maintenance. That said, I've read that it's recommended you change the transmission fluid around 90k miles.
I have a 2020 F350 6.7 and the transmission is starting to concern me. Aside from shifting very hard in 2 and 3 (it's always done that), the other day it shifted out of drive. I started to pull out of my drive and it just disengaged for about 10 seconds, coasted and then only revved until it banged into gear eventually. Thank goodness I hadn't pulled out onto a busy road. I've also had issues in 4WD. I was towing in some sand a few weeks ago and I put it in 4WD. it started to work fine at first and then wouldn't take fuel at all. It just died when I hit the the throttle. Of course I've had these things investigated at the dealer and they can't ever seem to replicate the issue. We are downsizing to a smaller motorhome and frankly I'll be glad to be rid of the truck. It's nice when it's working but I cringe at potential issues on such an expensive truck. I sleep better knowing it's still covered under warranty but I really worry about long term issues with it. Been lots of reported issues with the new transmissions and in most cases Ford doesn't want to step up.
2023 FR Sunseeker 2400B MBS
Krusty
Calgary, Alberta,Canada
yup. Transmissions are now "filled for life". My truck will be 12 years old soon and I have never even checked the transmission fluid level. I think I will change it soon though. I believe the only 10 spd trans available in the super duty is the 10R140, so it should be the same one.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Likes to tow
Huntington WV
way2roll wrote: It's the same transmission and you are correct there is no scheduled maintenance. That said, I've read that it's recommended you change the transmission fluid around 90k miles.
This 7.3 gas with the 10 speed pulls my 5th wheel as good as my old 2005 Ram 5.9 Cummins. I did not want a new diesel due to all the changes in recent years due to EPA regulations MPG is almost the same, maybe a mile or two less towing but without the trailer it gets about the same mpg.... Just can't understand why no scheduled maintenance!
Sounds like a lemon. Ford is not using any new 4wd systems. And the trans? Idk.
Usually when I have a warranty issue like this I try to make sure I break it good so there’s no question what the dealer goobers need to replace!
FishOnOne
The Great State of Texas
Likes to tow wrote: I have a 2021 Ford F250 with the 7.3 gas engine and the 10 speed transmission. It was bought new and has 20k on the odometer. Supposedly there is no scheduled maintenance on the transmission! I've always changed transmission fluid in all my previous trucks at 30k miles but the dealer says this will not need it. There is no dipstick!
Its the same transmission but has a different torque converter.
The owners manual states to change the oil every 150k miles but I would change it around 60k. As for the dealer I would never go back to that one again.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
on the road
FishOnOne wrote: Likes to tow wrote: I have a 2021 Ford F250 with the 7.3 gas engine and the 10 speed transmission. It was bought new and has 20k on the odometer. Supposedly there is no scheduled maintenance on the transmission! I've always changed transmission fluid in all my previous trucks at 30k miles but the dealer says this will not need it. There is no dipstick!
I have to ask if Ford states 150k why 60?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
FishOnOne
Cummins12V98 wrote: FishOnOne wrote: Likes to tow wrote: I have a 2021 Ford F250 with the 7.3 gas engine and the 10 speed transmission. It was bought new and has 20k on the odometer. Supposedly there is no scheduled maintenance on the transmission! I've always changed transmission fluid in all my previous trucks at 30k miles but the dealer says this will not need it. There is no dipstick!
Because that's the service frequency I use and with over 250k miles my transmission has been flawless.
ggardne2
Livonia, MI
Fluid change intervals for automatic transmisison fluids are related to fluid oxidation/fluid additive depletion over a test cycle that is meant to represent an assumed worst case operating pattern for the oil. The ULV fluid utilized in the 10R140 utlizes a very refined base oil (Type III base stock) that results in a very stable fluid with stable viscoisty over the life of the fluid. It is this hihg quality base stock combined with the fluid's additive package that defines the lifespan of the oil. The stability of this oil is what drive's the high mielage fluid change recommendation. While changing fluid more often may seem like a good thing, fluid changes do carry the risk of introducing contaminants into the system, particulary if the shop does not use fluid exchange equipment. Modern automatic transmission controls are very sensitive to small particle contaminants so a shop that is not careful wtih their fluid change procedures runs the risk of introducing contaminants into the transmission fluid that can be detrimental to the valve body resutling in valve silting and sluggish valve operation. For this reason I generally am not a fan of early fluid changes unless the fluid has been subjected to a severe duty cycle (extended towing at maximum vehicle capabiltiy in high ambient temperature on grades, for instance).
edited 12/27/22 10:51am by ggardne2 *
Turtle n Peeps
California
It's nothing new. My 2006 BMW has a fill for life transmission. It's not a truck but it's still going strong.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
