RV.Net Open Roads Forum: Truck Campers: Broken Frame on a RAM 3500
 > Broken Frame on a RAM 3500
Page of 11
deltabravo
Spokane, WA
Posted: 12/29/22 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
You may have seen pics of this truck and camper floating around the interwbez for the last few weeks.
Here's an article about it that was published earlier today.
ROBERTSUNRUS
Salem, Oregon
Posted: 12/29/22 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, why is the owner guessing? All he has to do is open the driver's door and read the label.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
Camper_Jeff_&_Kelli
Seattle
Posted: 12/29/22 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Those really big truck campers should be on the bigger 550-5500 trucks. Bigger brakes too that way. I know my F250 is probably a little overloaded but not severely. I have the higher rated 3400 pound each load range E tires, heavy sway bars front and rear, Larger 5500-pound leaf springs in the rear and soon, 3 leaf heavier springs in the front, Firestone airbags which provide a third center support point to the frame directly above the axle and halfway between the front and rear shackles. No signs of frame stress at the usual break point between the bed and cab. I would really hate to have it do something to me when I'm on one of those middle of nowhere back roads like at Alamo Reservoir, AZ last year, (Alamo Rd.) when I sank into the deep road gravel. there were several bouncy parts to that road for which I'm glad nothing happened.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
joerg68
St. Ingbert, Germany
Posted: 12/30/22 04:42am Link  |  Quote  |  Print  |  Notify Moderator
How far is that motorbike behind the rear axle and how much does it weigh...?
towpro
Compass PA
Posted: 12/30/22 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Even that one is hard to figure out, but if you look at that piece of paper in the glove box that shows the slide-in weight and COG for THAT truck its easy, but you still have to go to a scale.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
JimK-NY
NY
Posted: 12/30/22 06:49am Link  |  Quote  |  Print  |  Notify Moderator
In spite of the owner's claims, it seems very likely that the truck was grossly overloaded. Most Ram 3500 diesel crew cab pickups are going to have a CCC roughly in the 4000# range. The camper itself has a dry weight of 4500#. Loaded and carrying a motorcycle it is likely to be well over 6000#.
There is another warning here for all of us. The CCC is based on that weight in the bed of the truck. Hanging a lot of weight well behind the rear axle is beyond what the truck was designed for.
towpro
Compass PA
Posted: 12/30/22 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Its an 12' camper, on an 8' bed so its not the Curt 34" extension that I used on my Arctic Fox 990 so maybe a super truss. That looks like an electric bike, so maybe 60 lbs?
I had that same truck but 2 yard older, and I was at my max GVWR with just an Arctic Fox 990 loaded for a long trip. (and the 990 is around 1500 lbs lighter than that camper according to literature)
we have all seen this type truck with this type load on it before. I bet something else caused this failure.
Previous accident?
I could not see what camper mounts are used.
That frame is a "no drill" frame.
rhagfo
Portland, OR
Posted: 12/30/22 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Where do people get these numbers???
CCC of 4,000# is average for long bed SRW 350/3500, DRW will be over 5,000# based on trim, we are talking diesel engines.
Geo*Boy
Unknown
Posted: 12/30/22 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Are we still beating this dead horse?[emoticon]
bighatnohorse
Cave Creek
Posted: 12/30/22 08:44am Link  |  Quote  |  Print  |  Notify Moderator
1)The owner has a Facebook page and made a comment about selling the truck camper and that he also owns a 5th wheel.
This raises the unanswered question about how the truck was outfitted and used. Does the owner own two trucks? Does the truck also have a 5th wheel connection?
2) If you've driven in Mexico then you know that the topes (speed bumps) are everywhere. The shadow of a tree can hide a tope. If one were to hit a tope with a big camper on it could damage the frame and more.
Again, it's an unanswered question (though comprehensive insurance should cover such an event).
Page of 11
