RV.Net Open Roads Forum: Filtering Our Diesel Storage Tanks For on Road Use
Search only in Tow Vehicles
 > Filtering Our Diesel Storage Tanks For on Road Use
Posted: 12/30/22 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Literally none of this is an issue.
LaQuinta, you’re 100% trying to find a solution to a problem that doesn’t exist.
Assuming you’re not running around punching out tanks on const equipment for free diesel and dumping contaminated fuel into your slip tank, you have ZERO need for a pre filter on the slip tank.
And if you hooked it up for ease of use (gravity w check valve) you couldn’t reasonably or easily put a filter on it.
But if you can’t sleep at night without triple filtering the fuel, frankly in the wrong order, then there are any number of 2mic 4 absolute spin on filters that will go on standard filter bases.
Just buy one.
The ONLY reason I could see this being of benefit is if you ran all your fuel through the slip tank filter first, it would virtually eliminate the need for the expensive Ram filters and you could probably cut your OE filter changes to like 50k miles or more.
But that’s double the work.
FishOnOne
The Great State of Texas
Posted: 12/30/22 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Turtle n Peeps wrote:
As said, the filters on your truck will take care of any particulate matter and other contamination. The only thing I "might" do is get a cheap water block filter in case any water gets in your bed tank.
CAT makes a really good water block filter.
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
spoon059
Just north of D.C.
Posted: 12/30/22 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Ram has the best OEM filtration system out there. You don't need anything else. Change your fuel filters every 15K miles and enjoy your truck.
2015 Ram CTD
2015 Jayco 29QBS
Turtle n Peeps
California
Posted: 12/30/22 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Link
Yep, thanks Troy, that's the one I would get. I haven't checked in a long time but CAT filters were reasonably priced.....at least they were.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
S Davis
Western WA
Posted: 12/30/22 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
If your tank is Metal I would be worried about the extra moisture, I have a 52 gallon aluminum and it forms condensation. I went with a dedicated moisture filter, and will get water out the drain.
SuperBus
Michigan
Posted: 12/31/22 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Notwithstanding the valid points on the vehicle's existing system, if you wanted to do a bang-up job of ensuring your fuel is clean and stripped of water prior to it hitting your truck's tank, you'd want to put in place a pressurized feed into a Fleetguard water separator then a Fleetguard fuel filter (or a single three-layer FG Nanonet $$$ - overkill in my opinion since this set-up becomes your primary filtration and your OE set-up is secondary). Alternatively, you can draw fuel through the filters with a downstream pump, but it is not as effective. This set up won't be cheap, and is somewhat repetitive, but it is the answer to your question. The new issue you'll have is knowing when to change your truck filters. The interval will be much longer but how much?
Another thought - some truck fleets have fuel tanks at their terminals. They do employ filters on the tanks, but it is normally a pretty "open" filter meant to catch larger particles and debris. This situation is not analogous to yours, as they have the factor of much, much more volume moving through the filter on the tank, hence it is large in physical size and also in media size (i.e. particle pass through). There are issues that still result in trucks getting towed back to the terminal because of "bad" fuel. Just food for thought.
* This post was edited 12/31/22 07:00am by SuperBus *
SweetLou
La Quinta, CA USA
Posted: 12/31/22 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Just buy one.
First of all, thank you for the information. Parts of the equation here which you don't know is that I summer in Washington, and fuel is 50 miles away. With the increase in prices, and Washington going to add another $.50 tax on every gallon starting 1/1, I wanted to put my transfer tank back into service. I live near Idaho border and will get y fuel there thus giving the middle finger to Inslee on the westside. In any case, my 12v transfer pump will do the 15 gpm so gravity not an option or desire. I don't lend myself to the mercy that someone else cleans all my fuel because if that were the case we would be in trouble. If the fuel was so clean at the pump, then why have filters on our trucks at all? I will put a spin on to catch anything that slipped by or that was introduced by the attendant hosing down the station. Sounds prudent to me.
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
ksss
Eastern Idaho
Posted: 12/31/22 08:22am Link  |  Quote  |  Print  |  Notify Moderator
We fill heavy equipment out of 110 gallon slip tanks. I have water/debris filters on the slip tanks and then the OEM filters on the equipment. Been doing this for almost 30 years. Never an issue with this set up.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
JRscooby
Indepmo
Posted: 12/31/22 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
We used a filter/bleeder on the air vent. When I installed a power pump, I would mount a switch near the vent, hoping be more likely to wipe dust away from it before pumping air into tank (Yes, fuel out, but air, maybe dusty air will go in to replace.
Don't open tank any more than need to, and wipe area of cap before you do. Keep nozzle covered, so dirt can't get in, wipe before stick in tank.
Cummins12V98
on the road
Posted: 12/31/22 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Just be SURE that are NOT Chinese knock offs!!! Geno's Garage is a great place to buy the filters they sell the real deal.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
