Cummins12V98
on the road
Two biggest reasons I live within 30 minutes of the San Juan Islands and Cascade Mountains in WA State.
SW tip of Lummi Island and end of road on Mt Baker pictured.
![[image]](https://i.imgur.com/Nh8BNoYl.jpg)
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
blt2ski
Kirkland, Wa
Ron,
View from top of Baker is pretty amazing too.
Come to think of it, Adams, Rainer, Olympus, Prussik Peak, and many others have good views too!
Lots of reasons to be in this part of the world.
Marty
2014 Chevy 1500 Dual cab 4x4
S Davis
Western WA
A lot of nice places to see, here is Mount Baker from the south.
![[image]](https://i.imgur.com/MLGlA9yl.jpg)
Cummins12V98
on the road
San Juan Islands, WA State Ferry and Mt baker.
FishOnOne
The Great State of Texas
Good vacation spots don't necessarily mean it's an ideal place to live.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
larry barnhart
wenatchee. wa usa
FishOnOne wrote: Good vacation spots don't necessarily mean it's an ideal place to live.
Maybe maybe not. Beautiful on a sunny day for sure. chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Bionic Man
To get back on topic, unlike many here, I would absolutely recommend some sort of filtration to go from your storage tank to your OEM tank.
I have a aux tank dumping into my OEM tank. Twice I have had in-tank fuel pump replaced due to failure. While the dealer won't give a definitive cause they say it is possible that debris caused the issue.
I now have a diesel safe small inline fuel filter between my tanks. It is clear, and when I changed it after 5000 miles I could see debris.
A fuel filter is inexpensive insurance against a $1000 repair.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
So y’all that filter from slip tank to OE tank effectively don’t use the capacity of the OE tank?
Of it’s ok to fill the OE tank without filter but only sometimes?
Or you fill the slip and transfer to the OE while fueling up so you get both full to take advantage (and a long frickin time) of the extra fuel capacity?
I’m confused.
Mainly because of the millions and millions of light and heavy duty diesels running high pressure injection pumps and many with lift pumps as well. None of these I’m aware of are set up with pre-filtering fuel prior to it entering the primary fuel tank(s).
For anyone reading this thread and thinking they might lose a little sleep over not pre filtering their diesel after it’s filtered at the pump and then filtered another 1 or 2 times (or 3 if you’re one of the add more filters “after” the OE truck filters, or the add a 2 micron Cat filter before the water separator guys), you can rest easy here and know that unless you happen to have one of a few particular older diesels that are common rail with inadequate factory filtration.
Neither of which are the models of trucks in question here.
