RetiredBob
Portage, MI
For many years, I've always headed east to I-69, south to I-65 at Indianapolis and on to Alabama. Google Maps/Waze want to route me west towards Chicago, I-65 south to US41/I63/I-69 (at Evansville), to I-24 to Nashville and I-65 to Ala. Time-wise it's about the same and distance is slightly shorter (not much).
Has anyone taken this route? If so, how are the roads, especially 41/63? Taking a new route after 25 years on the old one might be interesting. Driving a class A with toad. Thanks for any input.
Mfan
Otsego,Mi
I take 94 west to 31 south to 465 east to 65 south. that's from otsego
RetiredBob
Portage, MI
Thanks and Go Blue!
jkwilson
Indiana
You don’t want any part of 41. Traffic lights are common. I see no reason not to do 69 to 65 or just 69 to 24. Minor discontinuity of 69 at Indy, and again at Evansville/Henderson, KY, but no big deal.
Taking 31 south to Indy would be better than 41 by a long shot.
If you do choose 69, blow the horn at me just after exit 87.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
RetiredBob
Portage, MI
Thanks,JK, that's the info I was looking for. Think I'll stick to my usual route.
haste maker
alabama
After you pass Birmingham, Al on I65 find a place to stop & see what has shook loose on your rig...I65 thru Birmingham is horrible..but it's the shortest route.
Retried Teamster
2007 Allergo
paulj
Seattle
I think the main new thing in the last 25 years is that US31 in Indiana is divided limited access.
I69 Indianapolis to Evansville is also newish, but with, I think, still some gaps - that's a work in progress.
Take GMaps suggestions as just that - suggestions. For the most part they aren't based on "what's best for your rv", but rather a mix of distance (an objective measure) and speed (at best an estimate), yielding a "time".
Use Sat view and Steetview to get more details as to the road condition (and views), but for construction areas note the dates of the images. I uses these a lot, but more for western mountain driving.
valhalla360
No paticular place.
Check your settings. The only way I can get google maps to give the US-41 option is I select "avoid highways" option. Otherwise, it's between I-69 and US-31.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
jkwilson
Indiana
valhalla360 wrote: Check your settings. The only way I can get google maps to give the US-41 option is I select "avoid highways" option. Otherwise, it's between I-69 and US-31.
Might be set to avoid tolls. The bridge at Louisville on 65 is tolled.
