RV.Net Open Roads Forum: General RVing Issues: Slab sinking
 > Slab sinking
Missionstreet
PA
Posted: 12/31/22 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have a relatively new concrete slab that is about 23 by 13'. It is built on a bit of a grade with coordinated drainage pipe underneath.
It really is two pieces, 12x13 each. I noticed the side closer to the slope sunk about 1/4" to *gasp* 1/2" near the center where they meet after backing up into it and then changing direction again. (There is a perpenducular crack in the center to so it isn't sinking evenly)
Any thoughts?
MDKMDK
Free(er), for now, until the next "variant"
Posted: 12/31/22 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Join a DIY, contractors, or concrete pouring forum.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
time2roll
Posted: 12/31/22 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
I would assume the base was not properly prepared. What does the concrete contractor say?
675w Solar pictures back up
98coachman
North Idaho
Posted: 12/31/22 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
You can compact the ground until you are blue in the face and you won't reach 100 % compaction. The ground will still settle! The slabs should have been pinned together to eliminate uneven heights or seperation. Good luck, it will probably keep moving.
dedmiston
Coast to Coast
Administrator
Posted: 12/31/22 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Was the pad professionally graded and compacted?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Missionstreet
PA
Posted: 12/31/22 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
Humm I wonder how much it'll sink
Missionstreet
PA
This is existing from a previous owner
bucky
Raleigh metro
Posted: 01/01/23 03:27am Link  |  Quote  |  Print  |  Notify Moderator
Can you just live with it? It might be pretty pricey to correct.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Missionstreet
PA
Posted: 01/01/23 03:30am Link  |  Quote  |  Print  |  Notify Moderator
Sure a little uneven don't bother me. As long as it's not going to move enough to cause issues.
I have heard of polylevel something. I think foam injection that lifts concrete? Maybe cheaper than other alternatives?
valhalla360
No paticular place.
Posted: 01/01/23 03:52am Link  |  Quote  |  Print  |  Notify Moderator
A couple potential issues:
- The base wasn't well compacted and now it's compacting. As long as it stops and it isn't pooling water badly or otherwise causing problems, I would just live with it. If it gets bad or otherwise starts bothering you, yes, you can have a residential paving company come out and use injection to compensate for the sinking.
- How thick is the concrete? 4" thick and you can expect a 12x13ft flag to crack. There's a reason sidewalks typically have a 4-5ft joint spacing.
- Are there any signs of water washing away the base material? If yes, you need to stop that or it likely will continue to get worse.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
 > Slab sinking
