Mfan
Otsego,Mi
I had my driveway raised by the injection method. Very happy with the result, and it was a lot cheaper than I expected.
Missionstreet
PA
Mfan wrote: I had my driveway raised by the injection method. Very happy with the result, and it was a lot cheaper than I expected.
Would you mind sharing any more details?
shelbyfv
TN
You are lucky it's just a slab. One corner of my home foundation has sunk, as much as 1/2" depending on the season. From what I read it's going to cost $thousands to have it jacked up and stabilized. Contractors....
prichardson
Lafayette, La
What is coordinated pipe? Do you mean corrugated pipe; if so, and it is under the section that is sinking, it may have collapsed.
12th Man Fan
Flower Mound , Texas
The foam injection method is "Uretek " here in Texas. I had them level a carport slab several years ago and it stayed put.
Google Uretek and I bet they have a presence in your area.
Good luck.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Mfan
Otsego,Mi
The contractor I used was vdcconcrete.com. maybe $300.
Pm me if you want specific details.
deltabravo
Spokane, WA
Missionstreet wrote: (There is a perpenducular crack in the center to so it isn't sinking evenly)
Any thoughts?
Concrete has two guarantees, it gets hard and it cracks.
azrving
Oatman
There are companies that will drill it and shoot expanding foam under it to lift it. Probably some diy people on YouTube
Cummins12V98
on the road
Live with it, what is it hurting???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Missionstreet
PA
prichardson wrote: What is coordinated pipe? Do you mean corrugated pipe; if so, and it is under the section that is sinking, it may have collapsed.
Actually I meant to say perforated pipe. I have looked down from the side where it comes out on the slope and looks ok. Will try my Depstech scope for more details.
