Bruce Brown
Northern NY
larry cad wrote: Nice job Mr. Brown! You can be proud of your work. I also believe that dual pane windows do a lot to keep the RV warm in cold weather and cold in hot weather.
Thanks Larry.
ro_sie wrote: Great job! I cant believe that window people cant find a better way to seal those windows! Larry Cad, You are correct. double panes do make them warmer. Hanginin, babies can take a lot of time especially if you are being the main daytime care giver. I did my 4 and then took care of grans so moms could work. Love my grands! Still have one with me full time.
The windows in the RV lasted about as long as the ones in our house, and those are Andersons, so they're not a second tier window.
And absolutely grandkids are awesome! We'll be babysitting this Saturday.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
4x4van
California
Bruce Brown wrote: ^^^ I certainly wouldn't do it that way. Remember, somebody installed it once so it can be done again.
What you're describing sounds exactly like ours was, the one removed shown above. It wasn't any harder to do than the others. The only thing on that one was the weight. It wasn't terrible, you just needed an extra set of hands.
I ended up doing one of the small windows in one slide end - believe it or not that one was the hardest to disassemble. I watched the video of the DIY repair... Sorry, but mine are much more complicated. The passenger side top pane is above the large slider. The driver side is above the front A-pillar window (also fogged) AND above the driver's door. Many of the repaired windows, even those done by pros rather than DIYers, end up fogging again a year or so down the road. I also don't want to mess with window frames that don't currently leak by removing the entire frame and re-installing/re-sealing.
I'm still trying to determine what the downside of my plan would be?
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
opnspaces
San Diego Ca
Yes a glass shop can measure cut a piece of glass and have it tempered. They can even round or bevel the edge if you want. But it really sounds like you're doing it the hard way.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
oldave
Tx
You can't cut tempered glass, as mentioned they have to cut it and then send it out. A real pain. LOL
However they can cut laminated glass, that's what your windshield is and what all auto glass used to be.
I plan to stay with my double-pane glass,
Bruce Brown
Northern NY
4x4van wrote: Bruce Brown wrote: ^^^ I certainly wouldn't do it that way. Remember, somebody installed it once so it can be done again.
Can you get a picture of yours?
Yours sounds a little different, however most Class A are something like this;
![[image]](https://i.imgur.com/7l81xPT.jpg)
That one is ours, shown out in an earlier post, now back in. Sure there was more to it than the others but it still wasn't hard, not by a long stretch.
As to the downside of your plan, my thoughts are...
Tempered glass doesn't break easy
Tempered glass doesn't break clean
The panes fit within a frame. Even if you could get it to break clean and easy, you would still need to get within the frame to install the new one.
You also risk breaking both windows if you happen to hit the inside one a little harder than you planned.
Whenever I'm tackling a job like this, something I've never done before, I remind myself someone else did it before me. They're not necessarily smarter than I am, they just have more experience - and they only way I'll ever gain any experience is to do it myself.
So far that's worked out fairly well.
larry cad
ohio
Bruce Brown wrote: 4x4van wrote: Bruce Brown wrote: ^^^ I certainly wouldn't do it that way. Remember, somebody installed it once so it can be done again.
Well said Mr. Moderator!
Our Travel Blog
Bruce Brown
Northern NY
Another much bigger project I did awhile back was rebuilding a TT. This had suffered a large, long term leak and was basically junk. I knew it when I bought it and paid accordingly.
The point of this is I had never done this either, but how hard could it be? This was one of the most fun projects I've ever done.
I won't go into all of it, just some highlights...
It looked good on the outside...
![[image]](https://i.imgur.com/tcBoPFY.jpg)
It was rotten...
![[image]](https://i.imgur.com/KZkjw0v.jpg)
![[image]](https://i.imgur.com/gf9GDL1.jpg)
![[image]](https://i.imgur.com/Xw6LWOF.jpg)
So I fixed it...
![[image]](https://i.imgur.com/NBKerSt.jpg)
![[image]](https://i.imgur.com/S1PHnpw.jpg)
![[image]](https://i.imgur.com/NC3MlG6.jpg)
![[image]](https://i.imgur.com/Zn5cRHT.jpg)
After it was done it made a cross country trip then we used it as a rental for a few years before selling it. It's still in use today as a seasonal camper.
Don't be afraid, Youtube is your friend and normally people are happy to help - just ask.
