RV.Net Open Roads Forum: Tow Vehicles: EV alternative for light/medium duty trucks
Search only in Tow Vehicles
 > EV alternative for light/medium duty trucks
Page of 46
map40
Posted: 01/16/23 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Huntindog wrote:
Too many things do not make any sense.
At a time when we are all being pushed into EVs, and electricity supply is constrained.... We have companies with warehouses full of computers running 24/7 To "mine" fake money. The electricity wasted doing this could have far better and more productive uses.. Then this fake money is sold to a greater fool for real money in the hopes that an even greater fool will come along and pay even more for it. So long as we as a society fall into this madness, I do not see how we can possibly affect the climate in a positive way.
I have a long list of things that do not make any sense,,but this is enough for now
I would not put EVs in the same group as bitcoin... that is a whole different problem...
Alfa SeeYa
Life rocks when your home rolls
ronharmless
The far side
Posted: 01/16/23 08:21am Link  |  Quote  |  Print  |  Notify Moderator
If we can now ration electricity use by type (i.e. “wasteful”), we can also eliminate pools, hot tubs, saunas, nightlights, more than one clock, supplemental electric heaters (including block heaters), more than one refrigerator, electric garage door openers, etc., etc., etc. Until then, bitcoin has the same rights as EV owners. Then on top of that, they talk about banning gas stoves.
Huntindog
Phoenix AZ
Posted: 01/16/23 08:32am Link  |  Quote  |  Print  |  Notify Moderator
It is a different one for sure. If it wasn't for the fact that they suck up a lot of elctricity, which is likely not produced in a green manner.....We should just enjoy the show. Unfortunatly the big problem is that it still has a lot of followers.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
pianotuna
Regina, SK, Canada
Posted: 01/16/23 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know the wattage on the battery heaters used in EV's?
Regards, Don
Posted: 01/16/23 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Squirrel!
Reisender
NA
Posted: 01/16/23 09:20am Link  |  Quote  |  Print  |  Notify Moderator
It depends on the car Don. But generally speaking EV’s do it different than ICE cars. Unlike an Ice car that uses an electric element to heat metal, most EV’s use the power from the battery to heat itself, or in many cases the coolant which is circulated. But that only happens down till about 20 percent battery and then that gets turned off so the battery isn’t depleted. It also doesn’t heat it unless the owner decides to either pre-condition the battery in preparation for charging or if the owner wants to warn the interiour and defrost the windows. Even if the car is plugged in the power will still come from the battery, but the battery will be charging because it’s plugged in. The power for everything always comes from the battery. The only thing that changes when it is plugged in is the battery is charging.
So in answer to your question, you can use anything from 8 amps at 120 volts to 48 amps at 240 volts. But the battery won’t be heated unless the user or the software decides it needs it. Below minus 30 the algorhythm changes a bit from what I understand. But only if it’s plugged in. The coldest we have used ours over the years is about minus 30 so I can’t speak to colder than that. We don’t plug ours in if it’s out in those temps as the cord gets to stiff to put away. The car doesn’t care either way. It takes an extra 5 minutes to warm up and defrost the windows at that temp.
We have a garage but unfortunately it is often occupied for projects so it is not always available.
Hope that helps.
time2roll
Posted: 01/16/23 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Deleted
675w Solar pictures back up
Latner
Indiana
Posted: 01/16/23 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to Socialism!
JRscooby
Indepmo
Posted: 01/16/23 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Does not fit any definition of "Socialism" I have read, other than call any idea you don't like Socialism.
pianotuna
Regina, SK, Canada
Posted: 01/16/23 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hope that helps.
I should have been clearer
I wanted to know if the battery was kept warm while plugged in at temperatures down to -37 c (-34 f)--and if so, how much power does it use to do so.
I'd have access to level 1 charging.
I seem to remember that the Leaf does use energy from the battery bank to keep the bank warm. But really not sure at all
Page of 46
