RV.Net Open Roads Forum: Roads and Routes: Route into Yosemite Valley
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > Route into Yosemite Valley
StarkNaked
West Seattle, WA
Posted: 01/02/23 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
First, the reason I'm asking this question! The last time we went to the Yosemite Valley we came in on Hwy 120 and the Big Oak Flat entrance.
This route has a serious downhill grade starting near Crane Flat Campground. It drops 2,300 in elevation in just 10 miles. During the last trip we overheated the brakes on that grade. When we got to El Portal Road, the front brakes were HOT and stinking. We had to put the windows down through the valley to try and get the stench out!
We are coming Southbound on I-5 through Sacramento.
So, here's my question. Which route would you take to get into Yosemite Valley? Is it worth the extra miles on Hwy 140 to avoid the pass on Hwy 120?
Driving a 30-foot Class C.
agesilaus
North Florida
Posted: 01/02/23 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Did you downshift?? That saves your brakes. We had a Colorado Highway Patrolman stop us and clue us in on that many years ago.
No engine/exhaust brake I assume, that is one major advantage of Diesels.
Getting in Yosemite is going to call for major altitude changes whichever road you take.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
time2roll
Posted: 01/02/23 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Go the extra miles and take 140 if you need to avoid 120. Could take a different route up vs down if that helps.
I personally would take the fastest arrival time as I have been up-down all three of the west entrance routes without issue. Ok I am a bit slow up some of the grades and I don't consider that an issue.
+1 for going slower and using a lower gear. Also don't ride the brakes to maintain a steady down hill speed. More effective to coast up to the speed limit (if appropriate) and then use the brakes moderately firm to reduce speed 15 to 30 mph. Then coast up to speed again. Braking before the turns is best. The firm braking will better distribute the heat load to all disks and drums on all axles.
* This post was edited 01/02/23 08:51pm by time2roll *
675w Solar pictures back up
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 01/02/23 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
You didn't say if you were downshifting for those types of grades. You need to do that in the mountains.
In 12 years of driving a gasser 30ft Class C, I never once smelled my brakes. But she was always in second gear for the grades steep enough to merit a warning sign.
Take the detour.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
StarkNaked
West Seattle, WA
Posted: 01/02/23 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Several of you asked about downshifting. No, I did not.
I kind of thought with all the uphill at Priests Grade I was already at the top.
Didn't know how long or steep Big Oak Flat was till I was already on it.
agesilaus
North Florida
Posted: 01/02/23 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Well it an absolute requirement for mountain driving. My F350 and now the RAM do the downshifting for me when I engae the engine brake. But I do not think most gassers will. So you have to learn to shift into lower gear and let the engine and trans do the braking.
Downshifting in the mountains
valhalla360
No paticular place.
Posted: 01/02/23 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
While there are probably some variation in grades along the route, 2300ft in 10 miles is only around an average of 4% downgrade. That's shouldn't be an issue for a rig in decent condition.
1. Downshift as soon as you see a steep downgrade and try to keep the speed down. Once it gets to fast, it's harder to slow it back down.
2. If downshifting isn't enough, short hard braking (not locking them up) then let the speed slowly creep back up letting the brakes cool between uses.
If you get to a flat section where you can safely pull off part way down, consider stopping and letting everything cool off if you think you have been pushing the brakes hard.
Does your MH have a tow/haul mode and do you turn it on? With a MH, it should always be on. It will do a lot of this for you. First time you tap the brakes, it will downshift.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
StarkNaked
West Seattle, WA
Posted: 01/04/23 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Answers:
No, I do not have a tow mode. I do have an overdrive on/off switch on the shifter.
No, I do not ride the brakes. I brake firmly and release and coast.
Yes, this section works out to 4.356% grade. But it's still 10 miles of a 4.356% grade.
Once again, I was not asking how to drive in the mountains. I was not aware of the grade or the distance until after I was already on it. And there are only a few places to pull off in those 10 miles.
The question I asked was: Which route would you take to get to Yosemite Valley from I-5 Southbound?
The one that is shorter, but climbs to over 6300 ft. (Hwy 120).
Or the longer route that never goes over 4000 ft. and only takes about 25 - 30 minutes longer. (Hwy 140).
lane hog
Posted: 01/04/23 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well.... two people have already answered take the detour vs. the climb and another said it's a wash.
One thing I've learned in 20 years here is never volunteer too much information when asking for advice. Saying things like "I really smoked my brakes in the mountains" is guaranteed to open yourself up to unsolicited advice.
If you really want to have fun and see reactions, admit that you tow a 39' fifth wheel with a half-ton over in the Towing forums... [emoticon]
StarkNaked
West Seattle, WA
Posted: 01/04/23 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Point taken! And you are correct about how many threads on this forum take a hard turn from the original topic.
