RV.Net Open Roads Forum: Tech Issues: Leaf Spring Failure - Replace the Others?
 > Leaf Spring Failure - Replace the Others?
joebedford
Home for the summer.
Posted: 01/04/23 09:09am Link  |  Quote  |  Print  |  Notify Moderator
CarnationSailor wrote:
Why did the manufacturer replace everything?
The broken spring PLUS the broken hanger PLUS two blown tires PLUS two bent axles PLUS the fact that the same model our year +1 had heavier everything. I think we went from 5000lb axles to 7000lb (+ wheels, tires etc.)
I guess they realized that even though they were within spec, they would be spending too much on warranty repairs.
No, my RV wasn't overloaded.
I eventually replaced that TH with a tri-axle model. Only suspension problem since was a broken spring bolt on the rear hanger (both ends were still there but it was snapped inside the spring loop).
fj12ryder
Platte City, MO
Posted: 01/04/23 10:24am Link  |  Quote  |  Print  |  Notify Moderator
ronharmless wrote:
How many RV’s are on the road that have never experienced a spring failure? Yet somehow you believe you got 4 bad ones. I say replace them all, then send the old ones to me for proper disposal.
Well, there's "broken", and there's "need to be replaced". I'd be willing to be there are lots and lots of "need to be replaced" out there, but few realize it. The springs still work, kind of, but are kind of like worn out shock absorbers: you don't really notice how bad they are until they're replaced. When your springs start looking like W's, it's time. Most people simply don't look.
Howard and Peggy
"Don't Panic"
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 01/04/23 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Question?
Are springs now coming from China and if yes, when did that start?
shum02
Burlington ON CDA
Posted: 01/04/23 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
MEXICOWANDERER wrote:
Question?
China and India actually and yes it's been happening for a while.
Broke one last year hitting a nice pot hole. Replaced all 4 including one axle that was starting to lie flat. Age and mileage wear them out.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
ford truck guy
Pennsylvania
Posted: 01/04/23 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
IF you do not think the broken spring was from mis-use... heavy pot holes, always curbing it on turns, Then I would look at it like this..
It is probably a sign of things to come, replace all 4 and call it a day... look into the spring ratings and YOUR scaled weights, then decide if you want to go heavier or not.
Going heavier does NOT ALWAYS equal the best answer....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Slownsy
Posted: 01/04/23 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
My 05 FW had made in China springs and I broke 2 at different times always where second leaf ended, not overloaded. Has operated current FW with extra long second leaf that extends to where main leaf is attached, we call it military wrapped. And no issue.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
valhalla360
No paticular place.
Posted: 01/05/23 12:49am Link  |  Quote  |  Print  |  Notify Moderator
Same could be said for tire blowouts. Yet, crazy people replace tires that haven't blown yet...crazy.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
joebedford
Posted: 01/05/23 07:38am Link  |  Quote  |  Print  |  Notify Moderator
When my first TH was new, I had two blowouts and replaced them with whatever I could get "on the road". When I got home, I replaced all 4 because E rated tires were clearly not good enough.
CarnationSailor
Cathedral City, CA
Posted: 01/05/23 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the helpful responses. I will be replacing all 4 leaf springs with ones that are about 10% higher rated and of higher quality. I will be paying up for the higher quality, but the peace of mind I get in return will be worth it.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
buc1980
houston tx
Posted: 01/19/23 07:44am Link  |  Quote  |  Print  |  Notify Moderator
After 3 springs broke during the years I get fed up and install the IS .That system put the end of the worry to get stock on the road.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
